Sponsored by:
Sponsored by:
2005-2010 Clutch Line Replacement Question
Old 11-04-2010, 10:12 AM
JeremyAlan
JeremyAlan's Avatar
Default 2005-2010 Clutch Line Replacement Question
Hello all,
Quick question - Does anyone have any experience with the JPC or FRPP Clutch Line kits?
Back story - a portion of(or entire) clutch line is made of plastic, so when the line heats up at becomes enlarged, larger area for fluid, less pressure to the slave cylinder(from my understanding). So FRPP offers a clutch line replacement with flex tubing made of braided hose, only problem i see in FRPP's stuff is its $219.95!!! Now i have found one other company making a similar product, JPC has a clutch line listed on their site for only $69.95 which seems very well priced, how ever i was wanting to know if anyone thinks this is worth it? or would i only notice a difference in heavy use conditions? also is the JPC piece the entire line or only a portion?
thanks in advance
JeremyAlan is offline
Old 11-04-2010, 11:06 AM
marcuskeeler
marcuskeeler's Avatar
It's nice to buy an "all parts included" kit but in reality you could do this for $30 if you went out and bought the stuff yourself, it's only a braided line and two fittings. $219 for the FRPP kit is monstrous.
marcuskeeler is offline
Old 11-04-2010, 04:08 PM
svtsupremecy
svtsupremecy's Avatar
can you do this with the trans in the car? how hard is this to install?
svtsupremecy is offline
Old 11-04-2010, 11:20 PM
JeremyAlan
JeremyAlan's Avatar
I'm assuming un clip two fittings. Remove from between the bell housing and the pedal or something. Install the new one. Then bleed the system. But idk.
Old 11-04-2010, 11:46 PM
tigercrazy718
tigercrazy718's Avatar
so is this a mod i havent heard of before?
or is this really only something you should do if your clutch is going out
tigercrazy718 is offline
Old 11-06-2010, 01:18 AM
JeremyAlan
JeremyAlan's Avatar
its a mod, i wouldnt call it a wear item. my clutch is fine and the car only has >15k on the odometer.
found it again at another site.
http://www.cjponyparts.com/ford-raci...2010/p/M7512A/
Old 11-20-2010, 03:19 AM
JeremyAlan
JeremyAlan's Avatar
I would say this mod is like adding SS brakelines, more for feel, performance, and feedback than anything.
Old 11-21-2010, 09:15 PM
RyanV
RyanV's Avatar
FWIW I put the Ford Motorsport piece in when I swapped in the six speed........Not sure if it's a harder clutch pedal or if it works better because I installed it at the same time as the new trans and clutch. The TR 6060 however, is what should have came in the GT to begin with, its smoother than goose poop and makes the car fun to drive instead of the constant mashing I was doing with the 3650.......D and D has recently discounted the price of the swap kit to 3500.......
RyanV is offline
djbigskrilla
09-20-2022 01:04 AM
Urambo Tauro
12-17-2016 03:30 PM
Jskeezy84
09-08-2015 01:40 AM
MXBT187
08-20-2015 02:36 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: 2005-2010 Clutch Line Replacement Question
