Glovebox USB Mount for second USB port
Thanks! I think 1' would be fine, if you are going to use the same setup that I did. Don't remember exactly, but I think the two cables I used were about 1.5' each and sense you have to couple them together it gives you plenty of cable. Now if you can find a panel mount USB that goes to a mini USB and don't need to couple anything together...then I think 1' would be pushing it, because I'm not sure if that would give you enough cable to open the glove box fully. There's plenty of space behind the glovebox to tuck a little bit of extra cable away anyways and like I always say, it's better to have to much than not enough.
Hmmm....I haven't had two USB devices hooked up at the same time yet, I wonder if it would work using the Mode button on the steering wheel, maybe toggle through to it? I'm gonna have to try this now and find out.
I do know that the first time I hooked up my thumb drive in the glovebox it automatically recognized it and switched to USB2 on its own.
Your solution is much more elegant and better looking but you need a black USB cable with a right angle connector to get the benefit from it IMO! The main gripe I have about the console USB port is how you have your thumbdrive sticking out where it can easily break off. A right angle plug would reduce strain on the connection.
That was one of my worries or gripes as well (especially when it was plugged into my center console), which is why I put the USB extender cable on there, but I suppose a right angle adapter/connector would possibly work a little better.
jwog666
12-27-2021 08:09 PM
