My 2011 Mustang GT 5.0 dyno results
Most '11 5.0's dyno around 360rwhp with 0-500 miles on them. Around the 1.5-2000 mile mark, most '11 5.0's dyno around 380-390. An X-Pipe is a major power adder on the 5.0, usually 15-25rwhp, with 20+ to be had from a long tube header, as well. An intake, X-Pipe, and tune will usually net 410-425rwhp, adding in the long tubes, another 20 on top of that.
Thanks, VistaBlue. I wasn't aware of that. If that's true then I'm certainly reconsidering adding a 5.0 to the stable.
I've seen about 3-4 dyno results on stock and tuned 5.0's and, so far, the numbers have been in the 350-360 range stock; 375-385 tuned. I wouldn't expect a thousand or so miles to loosen an engine up that much, nor an X-pipe to add much power, if any, but I'm listening.
Those of you with 5.0's: as you dyno, keep us posted. I'm liking your engine more and more.
Here's another car that made 430 to the wheels. He dyno'd about 390 stock though after his motor broke in....
http://forums.themustangsource.com/f...da-cai-486366/
