Oil Catch Can for Super Chargered Engines....
#21
I am in the same boat as Haney has not respond to my email either. Looks like the price is the same as HMS... $165 plus shipping. While I do think these are a bit over priced, I really need a design like this one with the top/side fitting locations to better accomodate the front intake fitting. They currently have blue, black, and clear in stock.
Now I just need to make up my mind between black or clear... really leaning towards the clear just to get a litte more contrast under the hood. And will more than likely be mounting it on the CAI/airbox like geocomp
The vendor is vastperformance.com and I am working with someone right now via e-mail about getting one ordered.
#22
http://www.accmachtech.com/catchcans.asp
#23
#24
the JLT looks small enough that if you rig it so it sits close to the valve cover or TB using your stock PCV hose and hose clamps, you wouldn't need to mount it anywhere.
i used to have the steeda separator and did it this way. it was small enough where the hose would hold it up and didn't need to be mounted.
you just need to measure the hose length and cut it so it fits.
#25
I'm not sure if the UPR can has a filter inside?
UPR Oil Separator
http://www.uprproducts.com/mustang-b...-05-black.html
UPR Oil Separator
#26
Do you have some different angles of how it looks installed? I keep coming back to this set-up since it has the top inlet and would make for a much cleaner install with my E-force since the intake fitting is right in front of the drivers side cam cover.
Not sure if Haney still carries these though as their website indicates a new one is being released. But in doing some digging, I have found another vendor that carries this can. I am confirming price and available colors right now.
#27
Woohoo, luckily we don't drive VWs
$191.24
http://www.bshspeedshop.com/store/bs...catch-can.html
or these ripoff machines....$259.99
http://www.jlevistreetwerks.com/p103...duct_info.html
Almost worth it to buy this just for the mounting hardware...
http://cgi.ebay.com/ebaymotors/ws/eB...fvi%3D1&_rdc=1
$191.24
#28
Well I saw the JLT direct connect will not work obviously with the Roushcharger I have coming. This other one from Brenspeed doesn't look bad:
http://www.brenspeed.com/5032-06.html
#29
I'll never pay more than $60 for a separator.
The "husky" my supercharger came with seems to work just fine. My only complaint is the low capacity but at least you can see what's in there. A lot of the more expensive separators you guys are looking at don't even have a level indicator that I could see. Stupid!
#30
http://www.uprproducts.com/mustang-b...-polished.html
