tpms question
I tried that PVC pipe "fix" on my 2007 for a few months. It worked intermittently. I eventually got pissed off and drove over to a tire shop and just had them install the stupid the sensors. For my 2009 and now this 2010, I learned my lesson and just ponied up the extra money to have it done properly in the first place. The hassle of making that pipe, then dealing with it not even working 100% of the time ended up not being worth saving $250. I believe that fix may have worked better on the very early cars...
My experience with the Sensors & bands. For 2 years I fought with the aftermarket bands and sensors put into my aftermarket wheel. I finally go so fed up of having to keep re-balancing the wheels I pulled them out all together.( they kept moving & throwing the wheel out of balance) I took the sensors away from the car Approx 100 ft and took the battery cables off the battery. Let it sit for 10 minutes. Put the cables back on let the computer reset and the the sensor light blinks about 6 times when you start it up but then goes out. Those sensors are a big PITA! It all comes back to common sense. If you feel like a tire is going low. Stop and check. Why do we have to continually keep changing things for dumb people! My rant for today!
There is nothing wrong with being environmentally conscious, and actually, there is nothing wrong with being a hippie either. It is the FANATICAL guys who screw everything up and give the rest of their group a negative face. For example, soccer fans are not bad people, they are good people for the most part. It is the fanatical soccer hooligans who screw it up for all of them.
The only thing I can say is stand up and vote and make sure you vote out those fanatical and unreasonable people who pass useless laws and coerce regulatory bodies to create useless regulations.
Sorry, I'm ranting also.
My fix was to lay the old OEM rims with the sensors
out on the garage wall right next to where they should
be installed on the stang. When I start her up in the morning,
the sensors report OK air and off I go without a TPMS light.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
