Cold Air Intake Problem
Guest
Posts: n/a
Hey everyone, so here is the problem the other day I had took my mustang to a tune shop to get the cold air intake installed along with a new exhaust system. I recently purchased the mustang so I couldn't wait to start modding. Well the exhaust system installed fine however when the cold air intake was installed it was causing problems with my MAF throwing the air ratio off in the engine and miss firing the cylinders, basically stalling the stang. I was surprised the cold air intake would cause such a problem although it makes sense how the problem occurred. I was wondering if anyone had faced the same problem or if they had heard of such a thing to occur and how they went about fixing it. I'm thinking about taking it to a speed shop to have it tuned for the cold air intake and/or have the computer relearned for it. Thanks for any help guys
(also if it matters the cold air intake was a ford racing kit for the stang the shop I took it too said it fit perfectly)
Guest
Posts: n/a
well thats what I thought too however the shop I took it too apparently didn't have the tuner to do so. Unfortunately I had found this out after the car came out of the shop. I had also ask the mechanic if they had tuned the car after the install because I knew it had to be done, but when I did I didn't get a straight answer. But by getting a simple tune from a shop that actually does have a tuner should fix the problem including the MAF?
Another case of blatant incompetence...who is training these f'cking monkeys? What is required to become a mechanic these days???
Search this and other forums and you'll clearly know that even the no-tune-required CAI's can throw a CEL for running lean. The PCM's simply can't adjust for the additional airflow.
Stand-alone CAI ~ 4-6 RWHP
CAI & custom tune combo ~ 20-25 RWHP
Even a good custom 87 octane tune will run circles around the stock 87 tune. Find another shop. And BTW, you load your own tunes. Don't allow a shop to handle that for you.
(I'd be rich if I had a nickel for every time I've said that...)
What exhaust did you put on? The stock exhaust flows very well so ANY changes from the OE H-pipe back will only yield sound improvement; no power addition.
