Supercharger, Gauges,Fuel Pump and tune. Anything else??
Well I'm pulling the trigger on the Roush M90 and I know that its a complete kit but I wanted to make sure that this thing would be solid so I going to add the GT500 dual Fuel Pump kit as well. I'm also getting an Autometer Cobalt A/F and boost gauge plus a Tune from Bama because I have FRPP Cams.
My question is do I need anything else to ensure that my car solid with the Supercharger? Are there any other supporting mods that I should do?
I don't have headers yet and I probably should get them but will not having them restrict the supercharger a lot?
I apologies for all the question just looking for some advice and reassurance that everything will be OK before I order and after the install.
So long as it's a complete kit with upgraded injectors, spark plugs, etc you should be good to go.
Headers will help, but I don't have them and am still putting down plenty of power with my supercharger.
How many lbs of boost will you be running?
The GT500 fuel pump is overkill for an M90. Get a KB Boost a Pump instead. You really should do headers to get the full potential of those cams. Now that your supercharging you really should anyway. I've been very happy with Pypes headers and off road H pipe. Around 600 bucks shipped from Brenspeed. Great deal.
wow... No GT500 pumps man. There not going to help you in any way shape or form. That kit can run on a stock pump. If it were me I would go with a BAP and run it at like 70% simply for stability reasons, but I'm still running a BAP and the pump stock pump at my power level. As Timbos said, for just a little more then the price difference you can get the headers and X pipe.
No need to waste money on the fuel pump, stock is good with the M90!!! If you some more power, I believe the VMP upgrade with smaller pulley is the way to go. I'm running my M90 stock and is loving it!!! I did order a Moroso Oil Catch can....may want to look into that!!!
Which Spark Plugs should I get if they don't send me any?
Thanks for the tip, where did you order the catch can from?
