'05 Mustang will not shift into gear or put in park...HELP!! - Page 2 - MustangForums.com
Old 12-09-2010, 05:15 PM   #11
wayne613
wayne613's Avatar
Quote:
Originally Posted by 157dB View Post
A big tranny fluid slick in the driveway would indicate a leak
and that service would be needed. Not a trip to the stealership.
*snip*
Its also user servicable if the user is knowledgable.
That's still extreme cheese IMO. Putting that into the F-150's and others is just kind of a pimp-slap to the face.
Thing is, what if it's a slow leak? Not parked at home when it leaked? While still obviously unfamiliar with them, I assume these scenarios are still possible. To have to bust out a vacuum pump and such just to check and/or fill, my "WTF?"-meter is still pegged for that one.
wayne613 is offline   Reply With Quote
Old 12-10-2010, 10:28 AM   #12
mayo
mayo's Avatar
Quote:
Originally Posted by ziperhead View Post
For those that are unaware, the 5R55s is a sealed transmission and has no stick to check it.
That's good to know...now. lol
Probably why I take it to the dealership for service...im engine retarded.
mayo is offline   Reply With Quote
Old 12-10-2010, 10:59 AM   #13
Tylus
Tylus's Avatar
Read owners Manual
Sounds like your brake solenoid has failed and that is preventing the shifter from being put into or removed from park. There is the little white button under a cover plate. Like mentioned above, use that to bypass the solenoid and see if the problem is corrected
Tylus is offline   Reply With Quote
Old 12-10-2010, 01:07 PM   #14
wayne613
wayne613's Avatar
Same here, no way in hell am I touching most of the mechanical aspects of my car for mods or simple upkeep. Not the dealer in many cases, but still.
Iīd have probably known about this several years ago if I had an auto as Iīd be looking in the compartment for 20mins and while muttering expletives post/search for why I canīt find the bloody thing. While I donīt usually so much as change my oil any more, I do like to know enough to at least keep checking things in between maintenance visits.
I even like reading the instructions that come for doing the rear ends and such, no way in hell Iīd ever actually do it myself, but itīs nice to know whatīs involved.
Old 12-18-2010, 01:00 PM   #15
157dB
Cut & Paste Expert
157dB's Avatar
A selective leaky tranny that knows the difference between
your driveway and the walmart parking lot so it never leaks
when parked at home but does leak othertimes when not
parked in the driveway of its owner?
I would not give Ford that much design credit.
Shoulda got a manual tranny so you wont have to worry about
automatic transmission fluid levels. Ford did it to keep owners
from putting in the wrong fluid then claiming defective warranty
work.
157dB is offline   Reply With Quote
Old 12-18-2010, 01:42 PM   #16
wayne613
wayne613's Avatar
work.
The few leaky ones that amounted to damage from friends having this, leaked most of the contents out while away.
Really, do you check under the car before you jump into it every day anyplace you are? Home, work, mall?
As for myself, I don't have that issue, as I've had a couple auto transmissions, but never intentionally bought a car with it. Certainly, not this car.
Old 12-18-2010, 01:45 PM   #17
AzPete
AzPete's Avatar
I would say the OP either has an issue with the push button shifter release on the side of the shifter handle OR as mentioned, the shifter release solenoid that is activated by the brake pedal. As to the noise when driving, sounds like the wrong gear was selected by the driver. Keeping things simple at first helps sort out an issue. Just wish the OP would respond as to anything helping.
AzPete is offline   Reply With Quote
Old 12-18-2010, 07:41 PM   #18
Art161
Art161's Avatar
AzPete, O/T, but I love the last line in your sig!
Art161 is offline   Reply With Quote
Old 12-19-2010, 09:06 AM   #19
AzPete
AzPete's Avatar
Thanks....words I try to live by...lol
hesitating jc1 Speed Density/Carb/SSP section 4 08-29-2015 08:09 PM
LeMans Stripes In "Magnetic" Gray color? Mr. D Big Worm Graphix 3 08-18-2015 02:51 AM
T-45 Tranny Fluid: Syncromesh vs ATF? Greyshot 4.6L (1996-2004 Modular) Mustang 2 08-15-2015 04:32 AM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 10:22 AM
Trans issues codes P0732 P0735 P0775 Mnuckolls 4.0L V6 Technical Discussions 3 08-09-2015 09:54 AM
2005, 2006, 2007, gear, gearbox, gears, mustang, park, put, putting, shift, stuck, transmission problems, trouble, won't shift gears
