Sponsored by:
Sponsored by:
View Poll Results: Twin Screw or Roots
Twin Screw
50
84.75%
Roots
15.25%
Voters: 59. You may not vote on this poll
Twin Screw vs. Roots
Old 12-09-2010, 04:05 PM
Wally39
Wally39's Avatar
The bypass lets out the excess pressure not needed anymore when you romp on it and let off the gas quick. You don't want all that pressure in your engine if you let off the gas. The twin screws are designed so the only time they compress air is if they are spun up fast.
Wally39 is offline
Old 12-09-2010, 04:07 PM
302_GT
302_GT's Avatar
Ehh, I answered my own question with this one: the bypass is located before the internals. But it is not to let out excess boost:
http://www.whipplesuperchargers.com/...sp?ProdID=1233
It's to prevent the SC from making boost at cruising speeds, so your not hurting your fuel economy.
302_GT is offline
Old 12-09-2010, 04:47 PM
Big50
Big50's Avatar
FYI a twinscrew is a roots blower.
Big50 is offline
Old 12-09-2010, 06:13 PM
302_GT
302_GT's Avatar
Twin Screw is a different style SC than a Roots. The three styles of SC's are Twin Screw, Roots and Centrifugal..
302_GT is offline
Old 12-09-2010, 07:34 PM
JIM5.0
JIM5.0's Avatar
Not quite, screw lobes are different from the straight lobes (now colloquially called "Roots"). Think of it just like helical cut gears (just like in your rear diff) versus straight cut gears.
By this comparison, in terms of the classic SAT comparison-match-up, screw lobes are to helical gears as straight lobes are to straight cut gears
JIM5.0 is offline
Old 12-09-2010, 07:56 PM
Simon1
Simon1's Avatar
Originally Posted by 302_GT
LOL, I see the votes are pretty well speaking for themselves, and this was the answer I was expecting. But I was hoping for some more reasoning to back it up.
I'm curious to see how many people are familiar with eaton's Gen 6 TVS technology. The previous generation Roots SC's had obvious heat soak issues, but eaton seems to have made some major headway with the Gen 6.
My biggest argument with the twin screw is it's constantly creating boost. Even though it has a bypass so the boost doesn't make it to the engine, the SC still has the added stress of consistantly making boost.
Where the roots has the bypass before the internals, so the SC isn't under anywhere near the same load as a twin screw during cruising speeds. But you still get immediate boost at WOT.
There is a difference between making boost and pushing air. There is a restriction when boost is created. The roots and the twin screw will each move air and spin at the same revolutions at the same RPMs whether they are under boost or not. The only thing that changes under boost is the resistance (on the drive assembly from pushing air when the bypass closes) that is created when the blowers are under pressure.
There is a reason why Lysholm blowers are banned in some forms of NHRA racing. Efficency.
that does not mean the Edelbrock and Rousch TVS type blowers aren't bad asz blowers making really good power very efficently. Both of those blowers are great and are good choices for anyone wanting a postivie displacement blower.
Simon1 is offline
Old 12-09-2010, 08:05 PM
Simon1
Simon1's Avatar
What does spun up fast mean?
Basically you have to go to ZERO vacuum so that the bypass valave actuates and closes. This creates the resistance and then pressure.
It's based more on the load placed on the motor. Not a rapid application of the gas pedal. If you put your car in neutral and rev the motor, the car may make a pound or two of boost at a very high rpm. Put your car in 5th and cruise down the freeway and give moderate throttle input and the car will make tons of boost.
Simon1 is offline
Old 12-09-2010, 08:19 PM
JIM5.0
JIM5.0's Avatar
Now there is a name I have not heard in such a long time, the name Lysholm.
Prior to Whipple making screw-lobe blowers, Lysholm I believe was the first to do it, and back when I was a child, people called screw-lobe blowers "Lysholm" blowers instead of "Whipple" blowers.
And even back then, screw-lobe blowers were considered superior to straight lobes (A.K.A. "Roots" blowers) as far as pumping air into the manifold.
Screws have the advantage of creating a constant stream or compressed air going into the manifold where straight cut lobes have always made pulses of compressed air.
Another SAT comparison-match-up: screw compressors are to a jet turbine as straight lobe compressors are to a reciprocating piston engine.
The jet turbine makes continuous torque on the shaft where the reciprocating piston makes pulses of torque. In pistons, you have to wait for a combustion to get positive torque, where while you are in between combustions between cylinders, you get negative torque from internal friction (cranks turning in the journal bearings, conrods turning on the crank, piston rings rubbing on the cylinder walls, etc.) Sure the reciprocating piston is doing positive work from the point of ignition to the point the exhaust valve works, but as soon as the exhaust valve opens, the internal friction starts to do negative work on the engine. And of course, the inertia of the moving parts, especially the flywheel with positive rotating energy, continues to make the crank turn in a positive direction, otherwise, the engine would eventually stop turning.
And speaking of pumping work, even a straight lobe compressor is superior to a reciprocating (piston) compressor, and that is why no superchargers are of a piston design.
JIM5.0 is offline
Old 12-09-2010, 08:49 PM
Burns331
Burns331's Avatar
screws also compress air from one end to the other end along the length of the s/c unit. They also compress air threw the center between the lobes.
Blower spins the opposite direction and moves air around the outside of the lobes.
Burns331 is offline
Old 12-09-2010, 08:51 PM
Burns331
Burns331's Avatar
Some good reading
http://www.kennebell.net/techinfo/ge...romcatalog.pdf
Burns331 is offline
Quick Reply: Twin Screw vs. Roots
