Sponsored by:
Sponsored by:
What is wrong with my car?
Old 12-21-2010, 02:33 PM
  #31
COHF13
COHF13's Avatar
wats up yall. My alternator broke down too so I was wondering, I know this guy that has a junked up 2001 ford Explorer with a 4.0 same engine as the the 05 mustang sixer that i drive. You think if i swap alternators it would function properly. would they produce the same amps and ****.
COHF13 is offline
Old 12-21-2010, 02:54 PM
  #32
BigDinTexas
BigDinTexas's Avatar
Do you know if they are the same part number? If not, I am sure there are a number of online resources that will list part numbers for each and you can compare. Or if you are able, just go look and see if there part numbers on the alternators are the same. If they are they should have the same output.
Don
BigDinTexas is offline
Old 12-21-2010, 03:08 PM
  #33
muzzy
muzzy's Avatar
Autozone or advanced auto can check your batt & alt. Its one of the two.... No big deal, I would put my money on short in batt. Good Luck
muzzy is offline
Old 12-21-2010, 03:11 PM
  #34
muzzy
muzzy's Avatar
Have your alt rebuilt 35/60 dollars.....Get a new batt.
muzzy is offline
Old 12-21-2010, 03:43 PM
  #35
wayne613
wayne613's Avatar
So long as it does as many amps or better, your ok in that respect. As BigDinTexas states you can just look up the alternators via the part #´s and see their rated amperage. Being able to produce more than stock is a bonus. Just don´t want to be under the original.
As for fitting, that someone else will need to chime in, as I´m unsure if the fittings and sizes are standardized in any way.
wayne613 is offline
Old 12-21-2010, 08:37 PM
  #36
charliebrown266
charliebrown266's Avatar
Its not so much the voltage has how many amps when load testing! Have seen many batteries that are 12.5 volts and once you load test them drop to 5v or less
charliebrown266 is offline
Old 12-29-2010, 03:08 PM
  #37
kc5mhb
kc5mhb's Avatar
OK, took mine to the dealer this past Monday and guess what? The alternator was not charging the battery. Duh! I told them that on the first visit. What helped me is that I bought one of those little monitors that you plug into the 12V accessory outlet in the middle of the dash and watched it as I drove. Stopping at red lights and stop signs caused the voltage to drop below 12V. I relayed this information back to my service guy and within 2 hours they had it fixed. I had the extended warranty so I only paid $100 instead of $261 for the alternator. I tried to look online for a replacement voltage regulator for these but did not find any listed. Apparently they don't want you fixing these and would rather have the whole thing replaced.
kc5mhb is offline
Old 12-30-2010, 03:14 AM
  #38
wayne613
wayne613's Avatar
Good to hear they finally got it resolved for you.
wayne613 is offline
MXBT187
08-20-2015 02:36 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Mnuckolls
08-09-2015 08:54 AM
Mr. D
Wheels & Tires
08-08-2015 05:43 AM
Quick Reply: What is wrong with my car?
