Moroso Oil Catch Can install with Pics
Very nice catch can. I'm surprised it came with heater hose though ... you don't want to use that. Heat is not the issue like Moroso mentions and they completely dodged the oil compatibility question. You need something that's suitable for fuel applications, like fuel hose, otherwise the oils will penetrate, deteriorate and swell the rubber.
High Temp Vacuum Hose (Black Hose) - P/N FBN0800 ($3.83/ft)
Application: Gasoline, fuel and oils reinforced with textile braid.
http://www.aeroquip.cc/fbn0800-bulkhoseblackhose.aspx
You are correct, this is what I have on order...
Edit: I meant the Moroso hose is 3/8". I see you ordered the 1/2".
Not to thread jack....but here is where I got mine, OEM fit & inside baffles to keep the oil from venting into the motor.
http://focus.c-f-m.com/cfmbilletvalv...mustanggt.aspx
I installed a catch can last weekend. I can't wait to see what I get after a few hundred miles...
