Gear Rattle , Ford says its normal?
SO my car has been in FORD for about 1 month now . They have chnaged my clutch to a stage 2, brand new slave cylinder , they changed my 2nd and 3rd syncro . But i still manage to get gear rattle on 4th and 5th gear. They have now ordered 4th and 5th gear , but they are telling me that this is normal ? I kind of understand that gear rattle is normal , but this is quite loud . I have lowered the car, done the basic bolt ons and do have a short throw shifter on . Any ideas?
clutch is a stage 2 what? Spec?
i have no gear rattle whatsoever. i dont think you should have any gear rattle.
when you have the rattle, try and play with the handbrake by a little wiggle side to side and see if that makes a difference. dont pull it up. lol.
is it all throughout the rpms in 4th and 5th, or does it get better or worse at higher rpms?
I am with the other guys. When you say rattle, is it like a rattle snake sound? Or a small metallic clinking? Or the sound of a loose nut?
If possible, can you make a vid of this rattling noise and post it?
Tim
its more like something grinding . mechanic says it comes directly from the bell housing .this is the clutch i upgraded to http://www.americanmuscle.com/spec-s...gt-clutch.html
[QUOTE=onederful100;7361138]when you have the rattle, try and play with the handbrake by a little wiggle side to side and see if that makes a difference. dont pull it up. lol.
QUOTE]
Actually, mine when it's warmed up does have a metallic sounding rattle and sounds like it's coming from the shifter ( pro 5.0 ) but when I press my leg against side of the ebrake, it stops immediately....Which is weird...
QUOTE]
