Sponsored by:
Sponsored by:
cranks but won't run
Old 10-26-2016, 09:00 PM
4.o stang
4.o stang's Avatar
Default cranks but won't run
so I have a 2005 mustang v6 4.0 manual that we had to change the head gaskets and thermostat housing because the coolant started leaking into the engine. the cylinders and the oil were all filled with coolant and some people tried to tell us it could have been the intake manifold but after taking it apart we found nothing wrong with the intake and we cranked the engine a couple of times without the intake manifold to see where the water was coming from and it seemed to have been leaking in through the two middle cylinders so we proceeded to taking out the heads and changing the head gaskets. after changing it and getting it back together we decided to crank the engine again but without the intake manifold to see if it would leak again but it seems that the engine isn't leaking anymore. so after we got everything back together making sure everything was good we tried turning it on but the engine just cranks and won't start up. my brother has a theory that it would have been that all the sensors are messed up because we were cranking the engine without a lot of things connected. he thinks that just taking it to get all the sensors reset should solve the problem but he's not entirely sure and he also doesn't know much about ford he's owned and worked with Chevys most of his life. so if anyone has any ideas or if they agree with my brother that would really help thanks.
4.o stang is offline
Old 10-27-2016, 12:04 PM
C1Forged
Former Sponsor
C1Forged's Avatar
Double check your harness, and make sure everything is still working properly. Not sure what all you disconnected in order to test crank, but you might have something disconnected in regards to spark/fuel that is interfering with it catching ignition.
C1Forged is offline
Old 10-27-2016, 02:24 PM
4.o stang
4.o stang's Avatar
we checked everything, everything is connected right we have a good spark and we just cleaned and checked the injectors and they're spraying good.
Old 10-27-2016, 02:41 PM
C1Forged
Former Sponsor
C1Forged's Avatar
Check fuses to see if something blew during the cranking from mis-reading. Could be something simple.
C1Forged is offline
Old 10-27-2016, 03:12 PM
4.o stang
4.o stang's Avatar
yea that's true we'll check thank you
Old 10-27-2016, 07:37 PM
4.o stang
4.o stang's Avatar
well we managed to make it run but it only turns on with two things but being connected I'm not sure what they are but once it's running it only stays running If we keep it at high rpms if we let go of the gas it turns off any ideas of what it could be.
Old 10-28-2016, 11:30 AM
C1Forged
Former Sponsor
C1Forged's Avatar
Check the fuel pressure. Other issue could be bad o2 readings, or exhaust clog.
C1Forged is offline
Old 10-29-2016, 05:19 PM
4.o stang
4.o stang's Avatar
we found out some sensors are a little off but its because the car is off timing. does anyone know what could have caused it to get off timing
Old 10-29-2016, 07:56 PM
Moderator
JimC's Avatar
If timing is off, then you haven't properly set up your timing chains when you removed the head to replace the gasket. Did you use a degree wheel and get them set up properly?
JimC is offline
Old 10-29-2016, 10:04 PM
Simon1
Simon1's Avatar
That what I'm thinking.
Simon1 is offline
