Sponsored by:
Sponsored by:
Help 12 OBD2 codes all at once?
Old 01-14-2011, 12:27 AM
Bullitt6996
Bullitt6996's Avatar
Default Help 12 OBD2 codes all at once?
Hey guys, new to the forum here, but I have an issue. A couple of weeks ago, I dusted off the hoses and engine, and later that day I had twelve trouble codes hit...in a nutshell, I have had a check engine light on for two weeks since cleaning under the hood. Affected systems are the O2 Sensor circuits, Cam Position Sensor, Evap solenoid and valve control circuits. Any ideas? I don't think I should have 12 trouble codes hit all at once.
Thanks
Bullitt6996 is offline
Old 01-14-2011, 01:01 AM
PSUSkier
PSUSkier's Avatar
Can't really say with a bit more detail, but if you're suddenly throwing codes from all over the engine is it possible you knocked one of the harnesses to the ECU a bit loose?
PSUSkier is offline
Old 01-14-2011, 01:08 AM
Bullitt6996
I thought the same, but haven't been able to locate a loose harness. I'll keep lookin, but man do I hop thats all
Old 01-14-2011, 02:24 AM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
I would also consider the possibility that when you did the cleaning you damaged some electrical connections somehow.
Many people on the forums say you can hose and clean your engine with no problems but I happen to be one of the people that don't think that.
I use a rag and water to clean my engine. Sometimes degreaser.
But I will NEVER put a hose to my engine. EVER.
I will use a wet rag and rub the thing down so I can make sure I don't hit anything that will not enjoy being exposed to water or anything else.
Blacksmoke is offline
Old 01-14-2011, 03:14 AM
Bullitt6996
I don't use a hose for that, no way. I used a rag and some turtle wax protectant for the hoses and some of the plastic. I tried to go easy on it. What are the odds that its just a crappy fuel filter doin all this? I haven't had the chance to change it yet and my car has 55,000 on it.
Old 01-14-2011, 03:34 PM
Art161
Art161's Avatar
Does the protectant you used contain silicone? If so, the vapors might have gotten sucked into your air intake.
Art161 is offline
Old 01-14-2011, 04:17 PM
Roy_R
Roy_R's Avatar
Recheck all the connectors...
PS. I won't recommend that you spray water in the engine bay. Just look at the Spark Plug holes in the head, no way to get the water out. In addition, the wiring looms aren't wrapped properly, so water will sit in your wiring looms....
Roy_R is offline
Old 01-14-2011, 04:34 PM
Derf00
Gentleman's Relish
Derf00's Avatar
A dirty fuel filter would give your performance a noticeable hit if it was the cuplrit. How does the car run overall, Same?
I +1 on a loose wiring harness/connector somewhere. I'd trace the wire going from the Cam Sensors to their main trunk and from there, as far back as you can get.
Derf00 is offline
Old 01-14-2011, 08:53 PM
akdoggie
akdoggie's Avatar
Art has a good point. Different cleaners and silicone sealants can throw gobs of codes due to the odor they expel. Clear the codes and see what resets now. It may of been the cleaner, maybe wetness in a harness somewhere? Anyways there has been plenty of time to have those smells dissipate or moisture to evaporate. I'd do the reset and recheck first and go from there.
akdoggie is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Help 12 OBD2 codes all at once?
