Sponsored by:
Sponsored by:
HID problem...?
Old 01-24-2011, 11:36 AM
jessesimmons22
jessesimmons22's Avatar
Default HID problem...?
I installed my ddm tuning hids today and the headlights work fine but theres a problem with the fog lights....
The fog lights turn on and everything but after about 10 seconds the shut off...?
jessesimmons22 is offline
Old 01-24-2011, 11:38 AM
jessesimmons22
i forgot to add that only one of the fog lights does this... the other one works fine..
Old 01-24-2011, 11:43 AM
Nuke
Nuke's Avatar
I'm not familiar with HIDS but I'd try swapping ballasts (if you CAN do that) between the 2 fogs. If it happens on the other side, bad ballast.
Nuke is offline
Old 01-24-2011, 11:45 AM
jessesimmons22
ive tried that and it works fine on the other side...
Old 01-24-2011, 11:50 AM
Nuke
Nuke's Avatar
That's wierd. Look up the fog light wiring here http://iihs.net/fsm/?dir=1 and see what else in the circuit would cause that to drop out. You're obviously NOT blowing a fuse so off the top of my head, you're somehow dropping out the relay (as a guess). I'd help dig but I'm at work.
Nuke is offline
Old 01-24-2011, 11:55 AM
jessesimmons22
okay thanks man
Diode Dynamics
28
05-26-2022 12:02 PM
kawiguy827
09-22-2015 10:52 AM
Mobiusone stang
09-07-2015 08:46 PM
inyadreems
08-21-2015 09:10 AM
stangmods.com
121
03-09-2009 01:18 PM
Quick Reply: HID problem...?
