traction control toggle? possibility?
so first off how does traction control work....through the breaks? tranny timing? im confused?
and also i want a sort of toggle switch/mode instead of it automatically being on everytime i turn on the engine, cuz i usually dont use it unless im just casually driving long distances, because i like to drive my stang hard ... the way its supposed to be
so is there a way to toggle the traction control, if not how do i do it w/ my sct tuner?
Try the search function, it will help.
But to answer you, when traction control detects your tires slipping (burnouts, donuts, icy outside) it cuts some power from the engine and applies the brake until it no longer detects slippage. In nice conditions it limits fun, in bad conditions it can be dangerous.
There is no way to turn it off without a tuner. In the tuner there will be an option that says traction control, and you can turn it off through that.
The Traction Control is run by the ABS system and is linked directly to the wheel speed sensors. If one wheel starts spinning faster than the others the speed sensors relay that to the ABS. MustangFirstCar got the rest.
This mod defaults it to off and allows you to manually turn it back on. As long as you don't drive like a retard, the TCS is garbage.
http://forums.themustangsource.com/f...ff-mod-462075/
