Sponsored by:
Sponsored by:
the wrench is back! need serious edvice!
Old 02-01-2011, 05:43 PM
windveilblue4
windveilblue4's Avatar
Default the wrench is back! need serious edvice!
i posted a thread not to long ago asking questions of how to fix my throttle body, engine light problem. My 2006 was dragging really bad and acting like it didn't want to accelerate, otherwise known as "limp mode?" well last week i had my throttle body cleaned and my K&N air filter cleaned. i also used a bottle of STP to clean out my lines and switched to premium gas. Today i was driving and the engine light came on once more and the throttle light came right after. my car went to limp mode i pulled of the interstate and the rpms stayed real low and when i pressed the gas it would drag and take a few secs to pick up rpms and actually start accelerating, it dragged and stuttered really bad at low speeds and on deceleration all the way home, also completely cut off pulling into sears. the ford place was already closed but i managed to get it to auto parts and had them hoke up the machine to read my computer and these are the codes i received:
#1 P061B
Internal control mod
torque calculation
performance
#2 P2135
Throttle position sensor
sensor switch A/B
Voltage correlation
#3 same as #2
ANY ideas or solutions would be greatttly appreciated!!!!
thankss!
windveilblue4 is offline
Old 02-01-2011, 05:59 PM
onederful100
onederful100's Avatar
do you have an aftermarket throttle body?
onederful100 is offline
Old 02-01-2011, 08:27 PM
windveilblue4
engine is all stock besides K&N filter and intake
Old 02-01-2011, 09:41 PM
SpartaPerformance
SpartaPerformance's Avatar
P2135 possible causes:
• TP sensor shorted internally to VREF
• TP sensor harness is shorted to power
• TP sensor signal wires are shorted together
• Damaged TP sensor
There are diagnostic procedures to follow to help figure out what the problem is.
SpartaPerformance is offline
spamedic
09-09-2015 12:15 AM
raleigh05GTO
09-04-2015 07:09 AM
09-03-2015 07:14 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: the wrench is back! need serious edvice!
