Sponsored by:
Sponsored by:
possessed mustang
Old 02-04-2011, 09:20 AM
kevinmalec
kevinmalec's Avatar
Open the hood and check the ground wires and and make sure they are tight! If they are loose, it can cause issues. Also, inspect the battery terminals. You may want to take your battery to autozone or advanced auto parts and have it tested. Worth a try!
kevinmalec is offline
Old 02-04-2011, 09:50 AM
Tylus
Tylus's Avatar
Dead battery. The radio is your 2nd biggest clue besides it not starting
These new Ford act possessed when he battery is dead. It can be scary
Tylus is offline
Old 02-04-2011, 10:35 AM
aaquib1992
aaquib1992's Avatar
+1, mines also one of the newer(ish) model s197's and you'd think most of the bugs with the radio/battery would be fixed, wrong.
When my batt died, Radio went crazy(showed all kinds of weird symbols on the screen) and the car made some weird clicking(I think) noises.
aaquib1992 is offline
Old 02-04-2011, 10:43 AM
kevinmalec
kevinmalec's Avatar
FYI, When my battery needed replaced, it made a fast clicking sound.
Old 02-04-2011, 02:10 PM
cavediver
cavediver's Avatar
Your battery didn't make that sound, it was your starter solenoid making it.
cavediver is offline
Old 02-04-2011, 02:51 PM
Nuke
Nuke's Avatar
I wasn't going to make that comment earlier but since cavediver did... +1
Nuke is offline
Old 02-04-2011, 04:12 PM
Alec
Alec's Avatar
Sounds to me like the battery. Before winter, mine was starting to die. It wouldn't turn over, starter would make the clicking noise and all the electronics in the car were acting up. For instance, if I got the car to start, I'd be headed down the road and the lights wouldn't come on for a few seconds. Hard to describe, but it was definitely odd and sounds similar to your issue. I'd try a new battery
Alec is offline
Old 02-05-2011, 05:44 PM
kevinmalec
kevinmalec's Avatar
I should have stated my info a bit clearer. I didn't mean the car battery made the noise, I meant the noise occurred due the battery needing replaced.
Old 02-05-2011, 05:55 PM
wilkinda
2010 Section Moderator
wilkinda's Avatar
I think 99.9% of us already knew exactly what you meant.. the other 0.1%......
wilkinda is offline
Old 02-05-2011, 09:11 PM
pascal
S197 Section Modder-ator
pascal's Avatar
If your battery makes a sound, it's usually once and loud and not good. lol.
pascal is offline
Quick Reply: possessed mustang
