Are Steeda delete plates worth it?
#21
jesus I love you TYLUS you just saved me lol.. the guy wasnt going to have them shipped until saturday when he is going for his s/c install so I am safe now. I might consider the plugs, but I doubt it cause the deal on the delete plates was the only reason I was getting them.. Thanks again for saving my a$$ again man, good call
#22
the 2005-2008 have a seperate CMCV plate that the upper manifold bolts to.
the 2009-2010 have the CMCV molded into the intake like the 5.4 3v (2004-current) does.
You use the Steeda Delete Plate for 2005-2008, and a Steeda Delete plug for 2009-2010's.
The Steeda Deletes essentially remove the butterflies. This removes restrictions from the intake and allow for a slight gain in HP. Mainly only good for high RPM bands.
I want to do this, but I figure if I'm going to pull the manifold, I'll just do a blower install instead. It isn't hard to accomplish, but I'm lazy and have very little time to work on the car. That, and the CMCV delete doesn't gain you a ton of noticeable power that can't be achieved through other easier means first IMO
#23
just glad I saw this before you blew the money. The Plugs are a PITA from everything I've read. And they are prone to actually leaking and causing vacuum/brake problems. Search the forums and a few guys have used the plugs with a few DIY parts to make them more effective.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
09-24-2015 09:18 PM
