New Tires, Pulsating Brakes
A comeplete new rear assembly is a little more than 1,000. You won't need the entire thing. You will need an axle. Summit sells them and they don't cost much.
Here you go. Check first, I thought the V6 had a smaller differential.
http://www.summitracing.com/parts/MSR-A882805/
You could replace the entire rear axle with a new take off 8.8" for A LOT less than they quoted you to repair the 7.5" on the V6 (2005-2010 model years had the smaller rear axle). Plus with the 8.8 swap you get the Tlok that the 7.5 lacks and the added strength of the bigger differential.
09-16-2015 07:53 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
