tpms sensor question
Ok so I have been looking for new wheels and tires for my 07 gt, and I have come acrose that I need to buy a tpms sensor kit or a new bracket for the new rims. so my question is when the time comes, I have to buy four new sensors or four new brackets right? cause each rims has one right?
I don't think your '07 uses TPMS. Check your owners' manual (and your dash for the indicator lamp when you start it up) to be certain. Should your car not have the TPMS system, you absolutely do NOT need to get them. Online wheel sources only talk about TPMS because later model years that use the same wheels do have TPMS.
Of course, even for a 2008 and up car you can still get and use wheels without TPMS, provided that you're willing to live with the TPMS lamp remaining lit. As far as I know, there is no Federal requirement to keep the TPMS system fully operational with sensors mounted and transmitting pressure information, only that you can't disconnect or remove the lamp.
Norm
Norm
If you do order the sensors, you need to buy 4 of each. Do not buy them from the fors dealership, they are almost 100bucks each. you can get all 4 online for that price. My winter rims I never added the senors, sometimes the warning light come on, other times it does not... weird.
But like Norm said, check if the 07 has it.
Norm
Norm
Sorry guys, but you are all incorrect.
2007 model and later by federal law required the TPMS sensors be installed. If you have a 07, you have the sensors.
You cannot just reset the sensors the light will never go off permanently.
You do not need to buy 4 new sensors, you only need to purchase new bands for the sensors. The sensors can be moved to your new rims, as long as you purchase a new "set" meaning all 4 (1 for each tire) of bands.
I purchased mine at Discount Tire, so you can pretty much get them anywhere, then they can mount your existing sensors on your new rims.
Once installed whoever mounts your tires or even the dealership can re-adjust them to work on your new rims.
Norm
Norm
I think I paid $50 bucks while I was getting my rims/tires installed to have them put new bands on. It wasn't bad at all, it will be more if you do it after the fact, but I hate lights on my dash
That's exactly why they won't let you disable the lamp - so that the nuisance value of it always being on will **** you off enough to make you go get it corrected. The Federal discussion on this point says exactly that, though in somewhat different language.
I don't care to be manipulated like that, for something that was brought on mainly as a result of a relatively few problems that occurred in completely different categories of vehicle and tires (Explorer).
I know that TPMS was phased in over some period of time, with some cars getting it before others. And I think the mfrs could get some sort of credit by adding it into their fleet faster than the gov't-set schedule. But I don't know just when any given model got it; it could have been as simple as a running production change.
Norm
Norm
