Unique Situation - Cluster Swap - Disabling Passive Anti Theft System (PATS)
Alright guys and gals... I have a somewhat unique question for those who may have dealt with PATS before. Here goes:
- I want to swap out my cluster for the GT500 Cluster
- From what I understand the PATS (passive anti-theft system) would need to be reset/reprogrammed by the dealer after the cluster swap in order to start the car
- If I can get a tune that disables the PATS system before I make the cluster swap will the car start after I make the swap?
- I won't be able to go to the Ford dealer to get them to reprogram my keys because my keys are no longer "used" since I have the Digital Guard Dawg push start button system installed. My car uses key fobs now and no keys at all. When they hooked my system up the left one of the key heads with the factory chip in it behind the steering wheel so that the PATS system will read it.
- My install guy said that the dealer won't be able to reprogram that because of the way it's set up now.
Anybody have an idea if disabling the PATS system before the cluster swap will solve my problem?
Dmhines put the GT500 gauge cluster in his car. I'm sure he can help.
His install thread has a lot of details: http://forums.themustangsource.com/f...010-gt-490121/
I also read another post where someone did the swap and didn't have to reset anything. It's just not clear and I don't want to take the risk if I don't know beforehand exactly what is going to happen.
Thanks. I read that post already and he had to get the dealer to reset/reflash his system after the swap. My situation is a bit different since I'm not using factory keys anymore.
http://forums.themustangsource.com/f...477780/index2/
That post contradicts the post where the guy had to take his car to the dealer because of the PATS system. Wish I knew which would be the case in my situation.
Here's the thread I was talking about where they made the switch with no issues.
Just sent you a PM.... I ordered the 2010 GT500 Cluster from a dealer and it will come programmed with my VIN and mileage. From what Steve told me, as long as he orders the GT500 cluster that was manufactured during the same "build time" as my car then I shouldn't have any issues with the swap. Evidently there are 6 different part numbers for the various "build dates" for the 2010 GT500 clusters. I'm hoping he's right and I don't have issues.
I'm getting a custom tune that will disable the PATS system and I'll load that tune before I make the swap. I'm hoping that will work.
Going to the dealer will be my last resort, mainly because the Ford dealers around here are clueless and I don't want them messing with my car. Push come to shove, I'll go to them if necessary, but trying to prevent it.
The charged me 330 bucks for the cluster itself and there was a 300 dollar core charge. Once I send them my stock cluster I get the 300 dollar core charge back, so yes, the stock cluster is an acceptable turn in.
