Need Wiring Color Help
#22
#23
would it cause the fuse to blow if the ilumination FROM THE RADIO was connected to the yellow (constant)?????
#24
yea i also think it was grounding... but i cant tell because im telling him over facebook chat how to fix and wire everything (normally im with him doing the wiring) so idk.
Putting all 3 on the battery would just equate to having a radio that would never go off on it´s own. That´s it.
But it works now, so happy days, and have fun y´all.
#26
Should you wish the illumination to function correctly, it will have to be tapped after the dimmer control somewhere. I don´t think a single mustang has ever actually had an illumination line run to the radio harness, ever.
The easiest method I´ve heard of is from black and white wire coming off the dimmer wheel on the dash, tap it and run a line to the head-unit directly.
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
