Pics: GT500 Cluster "Finally" Installed - Workaround Mod - Sorry for the Short Book!
#21
Wow ... that turned out to be an expensivie overlay!!!
I would have bit the bullet and paid the dealer to install the GT500 cluster. You are missing out on the Red/White/Blue special MYColor THEME ... and most importantly .. you are not getting the customizable SHIFT LIGHT and TONE .... I have the SHIFT LIGHT/TONE set for 5500RPM and I use it all the time ... My reflexes aren't that fast so by the time I actually shift after hearing the tone it's closer to 6K rPM .
#22
#24
Didn't really think about the ODO, but to me the speedo is referenced more than the ODO, and the ODO would theoretically be incrementing only 3 miles for every 4 miles driven. The shift points could be more of an issue if they are speed based rather than engine RPM based. I guess a quick call to your tuner would answer that question.
Just thinking outside the box as far as workarounds go.
#26
#27
Not sure how old this post is but I just did the same thing. I bought a damaged 2010 GT500 cluster and just swapped the overlays with my 2012 GT. One thing I did was keep the center 4 pack gauges the same so they would read correct to my year and model of the car. As far as lining up the tech and speedo I just reinstalled the cluster with out the needles and the clear plastic cover. I let the car idle for a few minutes to its norm idle and then just slightly pressed the rpm needle on and pressed the speedo needle to zero. removed the gauges and pressed the needles all the way in and reassembled every thing back and I was done. Also I did use a speedo app on my iPhone to check my speed and it was right on the spot to my old gauges.
#28
inyadreems
08-21-2015 09:10 AM
