Has to be too good to be true
#21
exactly. That pos will LOWER intake air and lower hp..
Whats the problem? I find it completely believable that you might lose 20-35 hp by installing this.
If your going to try something like this atleast make sure your fan blade is efficient and doesnt have a flat spot taking up half of your intake tube.
Also good luck with simply feeding your engine more air and hoping it realizes its now "supercharged" so it can add gas.
This remind me, i do have an old leaf blower sitting around. Time to add some BOOST!
#24
If anybody has extra money to just flush down the toilet,. I would love to see someone buy this POS and actually put it on the dyno. This thing has gotta restrict airflow and lower HP at high RPM.....but I want to know by how much HAHAHA
#26
#28
We all know this unit won't work, but I definitely think an electric PSI booster is a feasible idea.
I think the electrical demand and size of motor are the limiting factors.
Does anyone know how much CFM the blower would need to move to increase PSI?
How much CFM do our 4.6's pull at WOT?
#29
#30
The way I see one actually working, I see a proper screw compressor and manifold mounted on the engine. But instead of a belt turning the lobed rotors, a high torque electric motor does the duty. The motor will be a variable speed motor, and its RPMs would be completely independent of the crank RPM.
As a matter of fact, such an electric supercharger would be able to provide its most efficient boosts even if the engine is idling. (Not useful for the fuel-air curve to engine RPM, but hey, it would be possible).
Such a electric supercharger can be tuned with much more exact compression curves for the demands of the engine at every single RPM point throughout the entire RPM bandwidth.
And, no, such an electric supercharger will not cost $200. It will be big dollar, above $6000. And then, tables must be created to turn the compressor at the correct screw RPMs according to crank RPMs, fuel amount being shot into the engine, etc. Maybe a whole separate ECU might be needed to because the stock ECU might not have the circuitry to handle these additional tuning tables.
