BC RACING coilover install - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 04-07-2011, 03:34 PM   #11
DRock
DRock's Avatar
How much lower should i go? lol
DRock is offline   Reply With Quote
Old 04-07-2011, 03:59 PM   #12
09cs
09cs's Avatar
Quote:
Originally Posted by DRock View Post
Slammed
That low :look: haha
09cs is offline   Reply With Quote
Old 04-07-2011, 04:42 PM   #13
DRock
DRock's Avatar
Undrivable? Yea sure y not
Old 04-07-2011, 08:36 PM   #14
09cs
09cs's Avatar
THAT'S THE SPIRIT!
Old 06-10-2011, 10:32 PM   #15
Benjamin T
found this thread while doing search... are these coilovers chromoly or steel? and are they as heavy or heavier than the stock components? i tried going to the bc racing website but found no info, not even spring rates.
also wondering if you have the camber plates installed? if so, how do you adjust them? i am looking at my stock setup and the hole at the top of the shock tower in the front is so small i don't see how a camber plate could be adjusted without having to pull the strut out every time?
Benjamin T is offline   Reply With Quote
Old 06-10-2011, 11:32 PM   #16
Kixsters
Kixsters's Avatar
I really want coilovers now... i want my 5.0 to be slammeeeeed !
Kixsters is offline   Reply With Quote
Old 08-15-2011, 08:54 PM   #17
shark tales
they are machined. they are heavy but by no means heavier than the oem units. you have to also consider these struts are way thicker as well. spring rates are 7k front 5 rear. camber plates come included for our cars. without a strut bar camber can be adjusted from the top of the strut mount. i think coilovers is the best suspension mod hands down. some good tires and the pos live axle actually does really well.
shark tales is offline   Reply With Quote
Old 05-08-2012, 02:08 PM   #18
kingnut
drock i guess you have had these a year now, so you should know the setup pretty well. a couple of questions.
1: what spring rates did you get?
2: what is the minimum drop front and rear?
3: how has your ride quality been?
kingnut is offline   Reply With Quote
Old 05-08-2012, 03:01 PM   #19
DRock
DRock's Avatar
Holy dead thread batman!
1. When i got my coilovers, the rates were 8k and 5k. The rear is stiff just so you know. A lot of people wont like the rear that stiff.
2. Minimum drop in the rear is about a 1.25 drop give or take a lil. Minimum drop of front is higher than stock ha.
3. My ride quality is ok but i have a lot of suspension stuff, so that could have a negative affect on how my car rides and I drive around with the car set to pretty stiff anyways.
BTW the car is now wayyyyyyy lower than that
Old 05-08-2012, 03:02 PM   #20
DRock
DRock's Avatar
2015 Mustang Expansion Tank Granatelli Sales The New S550 2015-2017 Mustang 20 03-16-2017 07:33 PM
HELP.. Should I buy this fox? raleigh05GTO New Member Area 5 09-04-2015 07:09 AM
New member and just bought my first mustang Luke9222 New Member Area 7 09-04-2015 06:46 AM
Best Place To Run Power Wire/Firewall '08 cbird1177711 2005-2014 Mustangs 3 09-02-2015 08:51 PM
HELP A/C Wont blow cold, electrical 2008 cbird1177711 2005-2014 Mustangs 0 09-02-2015 04:12 PM
05, 0509, 2011, bc, coil, coilover, coilovers, gt, install, installed, installing, mustang, overs, racing, slammed
