Sponsored by:
Sponsored by:
Grinding noise at low speed
Old 04-03-2011, 08:18 PM
key_on
key_on's Avatar
Default Grinding noise at low speed
Looking for thoughts on the cause of a grinding noise at low speed ... generally 10-25 mph. Above 25 mph the grinding noise is not noticeable and cannot be felt, although there seems to be much more road noise than there used to be at all speeds. The car is a 2010 GT auto with 12K miles. This grinding noise has become noticeable in the last 1000 miles. It can be felt through the brake pedal and steering wheel. It occurs regardless of whether the brakes are applied or not. The tires were last rotated at 7500 miles.
I plan to have the dealer look at the car next time its in for an oil change, but was curious if anyone else has experienced this.
key_on is offline
Old 04-03-2011, 08:22 PM
bakerjd
bakerjd's Avatar
I had something similar happen before but don't know if it's what's going on here. I had a small rock wedge itself in between my caliper and rotor and it made a squeeking/grinding noise...My solution, which probably wasn't the best, was to go WOT and the rock kicked free. Like I said though, this could or could not be what's going on with yours.
bakerjd is offline
Old 04-04-2011, 10:09 PM
key_on
key_on's Avatar
Thanks for the idea. Probably ought to pull the wheels and see if something is there that shouldn't be.
key_on is offline
Old 04-05-2011, 10:16 AM
FordService
Official Ford Rep
FordService's Avatar
Hi key_on,
My name is Deysha from Ford Customer Service. I recommend you contact your dealership as soon as possible. If you need further assistance, please message me with your VIN, dealer, contact info, and mileage.
Deysha
FordService is offline
Old 04-05-2011, 10:31 AM
Nuke
Nuke's Avatar
Since you're still under warranty, get your butt to the dealer before it fails catastrophically and leaves you stranded. That noise is your car telling you something isn't right. Waiting for your oil change is NOT the correct response.
Nuke is offline
Old 04-05-2011, 12:50 PM
bigblue95z
bigblue95z's Avatar
Jack up thefront and spin the tires. See if you can hear anything. But with the warranty get it in to the dealer.
bigblue95z is offline
Old 04-05-2011, 09:10 PM
key_on
key_on's Avatar
Originally Posted by FordCustomerService
Hi key_on,
Deysha
Deysha and everyone else,
Thanks for the responses, ideas, and offers for help. I plan to contact the dealer tomorrow.
I took a close look at the front tires today. Both are cupping on the inside edge, indicating a problem with the alignment. The car drives straight as an arrow, but just looking at the way the car sits, it appears to have excessive negative camber.
Not sure if alignment at 12K miles is covered by warranty, but I guess I'll find out tomorrow.
key_on is offline
Old 04-12-2011, 08:21 PM
key_on
key_on's Avatar
Default Update to grinding noise in front end
I took my car to the dealer to have the grinding noise diagnosed. As I suspected, the alignment was off and had started to feather the inside edge of the front tires. Its amazing how much noise and grinding vibration can be transmitted through the steering wheel and brake pedal when the tires are wearing abnormally.
Anyway, got the front end aligned and rotated the tires front to back. All is smooth and quiet now. I wish the alignment had been covered by the warranty, but no such luck. I'm just glad to have the car sounding and feeling right again.
key_on is offline
bjdutch2005
03-24-2017 03:38 AM
musnicki
09-23-2015 07:11 AM
degner122
09-16-2015 07:09 AM
movielover40
09-15-2015 10:37 AM
Quick Reply: Grinding noise at low speed
