Sponsored by:
Sponsored by:
Painted valve covers
Old 04-25-2011, 07:49 PM
grabberorange1
grabberorange1's Avatar
Looks good...I did mine a couple years ago...I followed these instructions, it is more intimidating than difficult, you can't really screw up the way the plugs are secured in the harness'... check this link out http://www.cherod.com/mustang/HowTo/ValveCover.htm
grabberorange1 is offline
Old 04-25-2011, 08:08 PM
allinon72
allinon72's Avatar
I used taco bills diy as a guide for removal. Took about 20 minutes per side.
https://mustangforums.com/m_3402092/tm.html
Once removed, I cleaned them with engine degreaser, sanded them with 220 grit, 3 coats of primer, then basecoat.
allinon72 is offline
Old 04-25-2011, 09:32 PM
bigblue95z
bigblue95z's Avatar
What type of paint should be used? Would any rattle can work, or should you go with a engine paint ext?
bigblue95z is offline
Old 04-25-2011, 09:39 PM
loots06
loots06's Avatar
Nice job..
loots06 is offline
Old 04-26-2011, 08:27 AM
kevinmalec
kevinmalec's Avatar
Paint quality looks outstanding! Great job!
kevinmalec is offline
Old 04-26-2011, 08:32 AM
D'prived
D'prived's Avatar
Those are purty! Nice job!
D'prived is offline
Old 04-26-2011, 09:50 AM
grabberorange1
Yes use engine paint...I did 2 coats engine primer, 2 coats Ford blue, and 2 coats of clear...
Old 04-26-2011, 01:11 PM
topbliss
topbliss's Avatar
looks great... Takes more then 20 minutes a side to get em off, too. (unless you have done it many times before) I powercoated mine..
topbliss is offline
Old 04-26-2011, 06:03 PM
allinon72
allinon72's Avatar
Yeah you're right, maybe 30 per side, but it's much easier following tacobill's instructions.
Old 04-26-2011, 06:36 PM
rydeordie
rydeordie's Avatar
Looks good! Nice job...
rydeordie is offline
Quick Reply: Painted valve covers
