+12v switched for raptor shift light?
(2010 GT, Raptop single stage shift light)
I'm looking for a +12v switched power source under the hood, preferably near the fuse (power distribution/relay) box. Alternatively, I could use one in the passenger kick panel fuse box area if I had to, but that might lead to some headache running the wire within the dash area.
I've been looking over the wiring diagrams on the link below, and on page 2 (I think the link is directly to page 2), there's a "hot in start or run" fuse, F19 5A "13-13", apparently located in the "Smart junction box". I looked under the hood and none of those fuses are 5amp, so I assume this indicated fuse in the interior fuse box, however number 19 is not 5 amp.
http://iihs.net/fsm/?dir=40&viewfile...20-%204.6L.pdf
Any suggestions? I've RTFM'd and found a warning specifically against probing the under-hood fuse box.
