Recognize this rattle?
06 GT, Automatic.
I originally thought that I had something loose inside my exhaust, but after removing it for a shake that is not the case. After really getting under the car while starting at it seems as though I have a buzzing noise coming from somewhere near the front-mid of the car that only occurs when I start after it sits for a few hours or longer and the RPMs swell and pass through around 1400 and when they fall again through the same.... I never hear the sound again until it sits for a while and then is started again. I have not experienced any kind of similar noise when driving the car.
It sounds to me like metal-on-metal contact somewhere but I have no clue where to start checking things. Curious if anyone could give me a place to start...
Here's some videos. In the first one the wheels visible are the fronts, so the camera is aimed at the firewall area...
Outside (Listen at 0:20-0:21 and 0:23-0:24 specifically)
http://www.youtube.com/watch?v=rnepdaredc0
Inside...
http://www.youtube.com/watch?v=-ixdsZikGtE
Inside...
Hi everyone,
Rattling noises can be very annoying! If you are unable to determine the cause of your rattle, you may want to consider having your Mustang diagnosed at the dealer. They will be able to pinpoint the source of the noise. You can locate the closest one here. Please let me know if I can be of any additional help!
~Natasha
~Natasha
Also from what I've read there is rattling when the car is driving, in certain gears, ect. My issue is specifically on start-up, after that there is no noise...
Keep us posted.
