Sponsored by:
Sponsored by:
Question - RPMs dipping
Old 06-10-2011, 06:45 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Clean the TB and check for vacuum leaks as stated.
If this does not cure the problem I'd say with CONFIDENCE it's the tune.
I went through the same problem in the 06GT and mine was tune related.
Blacksmoke is offline
Old 06-12-2011, 05:24 PM
Alec
Alec's Avatar
Today I bought some TB cleaner (CRC I believe) and gave the TB a thorough cleaning. It was disgustingly dirty but I noticed a very significant difference after cleaning it. Idle issues were gone, and the throttle response was much improved. Problem solved
Alec is offline
Old 06-12-2011, 05:33 PM
Nuke
Nuke's Avatar
Yeah, baby! I'm sure that's a relief.
Nuke is offline
Old 06-12-2011, 05:49 PM
Alec
Alec's Avatar
Big time!
Alec is offline
Old 06-15-2011, 09:54 AM
Alec
Alec's Avatar
Here's some pics showing how gross it was...
Before
After
Alec is offline
Old 06-15-2011, 11:19 AM
Roy_R
Roy_R's Avatar
That's why I have a oil catch can installed.....imagine the intake contamination.
Roy_R is offline
Old 06-15-2011, 11:27 AM
Nuke
Nuke's Avatar
Alec,
I've yet to pull my TB off. Did you reuse the gasket?
Nuke is offline
Old 06-15-2011, 11:39 AM
defiance
defiance's Avatar
Alec,
There is no gasket. There is a ring that is built into the plenum, im assuming they use that instead of the gasket now. Either way i removed mine numerous times and the only thing i did is clean around the rubber ring, never had a problem.
defiance is offline
Old 06-15-2011, 11:45 AM
Alec
Alec's Avatar
^^ yep
Alec is offline
Old 06-15-2011, 11:46 AM
Nuke
Nuke's Avatar
Excellent.
Nuke is offline
Quick Reply: Question - RPMs dipping
