Quick question about supercharger basics for the 4.6 - Page 2 - MustangForums.com
Old 06-19-2011, 02:00 PM   #11
Roush05
Roush05's Avatar
I'd be happy with an M90, even though it's a 'small' blower. However, where do I need to look to get it for $3000? The only places I've found them are at retail(roush, ebay, etc).
Roush05 is offline   Reply With Quote
Old 06-19-2011, 03:36 PM   #12
908ssp
908ssp's Avatar
Quote:
Originally Posted by SpartaPerformance View Post
A GT-500 blower is a complete waste of money. Once you piece together all the required components you've spent more then a FRPP Whipple kit in the long run. If you do a cost effective blower kit search on here you'll find a lot of members have the M90 blower kit and they got it for around $3,000. That is a great starting point.
Show me a kit with 450hp at the rear wheels for $3500 or close to it. The GT500 adapter will cost about that after you buy everything you need.
908ssp is offline   Reply With Quote
Old 06-19-2011, 03:57 PM   #13
stealth_GT
stealth_GT's Avatar
You could always get one of these for a little more than your budget
http://www.hotpart.com/shop/index.ph...ct_detail&p=12
it's pretty much a late gen Cobra style blower (M112) and more capable than the M90.
You'll eventually need a larger heat exchanger down the line if you upgrade the pullies for 10 psi.. people are making great power with these units on another Mustang site.
Also, take note on their advice on removing the washer behind the idler pulley as well as using an upgraded belt tensioner. It's been known to be a real "belt shredder".
http://www.youtube.com/watch?v=yY0bTemVOg4
http://www.youtube.com/watch?v=VmKe0fm7qHY
stealth_GT is offline   Reply With Quote
Old 06-19-2011, 06:16 PM   #14
Roush05
Roush05's Avatar
stealth, did you decide to keep your setup? I saw you asking about the valet mode I think?
Anyway, My end goal is ~430 rwhp. I figure most kits can put me close if not over pretty easily. From what I understand, at ~450 rwhp you start risking things messing up, and I'd like to avoid that if possible.
Old 06-19-2011, 07:20 PM   #15
stealth_GT
stealth_GT's Avatar
Yeah, I decided to keep it.. it's so easy to take on and off that I decided to save myself the money.
Seriously considered a 2012 Dodge Charger AWD/RT 5.7 but from what I hear, the 2011-2012 PCMs are real bastards to hack into and tune. Since I planned a Supercharger for that car, I will sit tight and wait to see what happens later on before I jump on that car.
450 is the safe number floating around the web, but some have made as much as 525whp and average around 480-490whp. 450lbs. torque is supposedly the real number, since torque being the more force behind the two. If I were you, I'd be patient and wait it out rather than being hasty and going on a budget.
The M90 is a fun supercharger. Lots of low end grunt even compared to the Centri's endless top end..
Old 06-19-2011, 07:25 PM   #16
Roush05
Roush05's Avatar
That magnacharger that you posted lists its install time as less than a day. is it that easy to install?
Old 06-19-2011, 07:31 PM   #17
stealth_GT
stealth_GT's Avatar
Pretty much your basic positive displacement blower set up; Top mount unit, front end assembly pulley set up, degas coolant bottle/canister routing, IAT sensor wiring..
doesn't get more basic than that, other than a centri air to air set up..
Old 06-19-2011, 08:43 PM   #18
Roush05
Roush05's Avatar
Dare I say I could do it myself on a weekend?
Old 06-19-2011, 10:55 PM   #19
808muscle
808muscle's Avatar
M90 might be a small blower but its big on fun. I don't have the smaller pulley and still running in the 12.2's. With that pulley I'm in the 11's. Its a great safe blower. I do have a new DS to install.....so my numbers will only get better.
Wait for a good kit OP. Don't slap one together.
808muscle is offline   Reply With Quote
Old 06-19-2011, 11:37 PM   #20
Roush05
Roush05's Avatar
I have about $700 put aside now and when I start back to work I should be able to afford a used kit within a month or two.
How to get good HP out of a 4.6 without spending big bucks. Luke9222 4.6L General Discussion 19 10-23-2015 12:55 AM
Shifting Mustangmalo General Tech 2 09-06-2015 06:22 PM
Matt Farah Takes On Supercharged GT With Seriously Short Gearing MustangForums Editor GT S197 General Discussion 1 09-03-2015 08:14 PM
46, adapter, add, cobra, intercooler, kit, needed, piping, plate, roush, stage, supercharger, v3, vortech, whats
