Sponsored by:
Sponsored by:
Wheel vibration
Old 09-04-2014, 08:11 AM
PNYXPRESS
PNYXPRESS's Avatar
Unless you modify your suspension or hit a curb the toe should not change.
PNYXPRESS is offline
Old 09-04-2014, 08:25 AM
jsimmonstx
jsimmonstx's Avatar
Or run over something on the freeway, or your tie rod ends are worn, or your LCA bushings are worn...
jsimmonstx is offline
Old 09-04-2014, 08:57 AM
Rudolph Hucker
Rudolph Hucker's Avatar
the dude that did my toe said they are rarely 1005 perfect even from the factory
get it checked coz mine was vibrating no matter what i did
had the toe aligned to perfection by a latest machine and bingo no vibration and no slight wandering at high speeds
Rudolph Hucker is offline
Old 09-04-2014, 09:28 AM
PNYXPRESS
PNYXPRESS's Avatar
if you have worn bushings or tie rod ends an alignment wont fix them. The ONLY way to knock the toe out of alignment is to hit something and bent or break a steering component.
Old 09-04-2014, 10:31 AM
jsimmonstx
jsimmonstx's Avatar
If you have worn suspension components, your toe will change while you're driving.
Old 09-07-2014, 09:59 AM
BlueBellThunder
BlueBellThunder's Avatar
Default Update on road trip
I made it to my destination of Minneapolis to visit family. The strangest thing with the wheel shaking is sometimes it's there and sometimes it's not. I can only really tell if I let go of the steering wheel. And sometimes when accelerating I'll notice it also. It's been my pet peeve to whole trip up here to every so often let go of the steering wheel for a couple of seconds to see if it shakes. On a flat road I let go of the wheel for about 30 seconds, no drifting at all, so I guess the alignment is fine. When I get back I'll have the wheels rebalanced and see if that helps.
BlueBellThunder is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
Quick Reply: Wheel vibration
