Sponsored by:
Sponsored by:
Had to add a 6 point roll cage to the convertible
Old 06-25-2011, 07:50 AM
Moderator
JimC's Avatar
Another friend with a convertible and I were standing there watching a motorcycle go down the track at 10.3 and about 130 mph and he had been pulled for running a 12.9 in his car. But I guess the thinking is that the guy on the motorcycle will be tossed away in a crash while we are strapped in to the car with the soft top overhead.
And Paul, I'm sure that you would get the same thing. Last year at Ubly they said "you can finish out today, but don't come back next year without the roll bar". At that time I was just dialing in the Xtreme and was running 13.1 - now it runs sub 13's
JimC is offline
Old 06-25-2011, 08:57 AM
Mikado463
Mikado463's Avatar
Nice job..........Cr Mo or mild steel ??
Mikado463 is offline
Old 06-25-2011, 09:38 AM
MeanStang08
ChopShop Mod-tator
MeanStang08's Avatar
very nice.. now get a 5 point harness and a fire extinguisher mounted on that bad boy!
I love those stripes... really does make it look cooler.. I've never seen anybody do that..
MeanStang08 is offline
Old 06-25-2011, 10:50 AM
Moderator
JimC's Avatar
thanks - and it is mild steel. Cro moly would have been a little more expensive. This one only cost me $1,100 installed.
JimC is offline
Old 06-25-2011, 02:00 PM
Newwt
Newwt's Avatar
are hard tops still set at 12sec or did they change that? Do that make a roll cage that does interrupt the back seats? Gonna have to get a Baby on board sticker one day.
Newwt is offline
Old 06-25-2011, 02:41 PM
forensicsteve
forensicsteve's Avatar
Nice tight looking fit. Hard to keep the utility of the rear even with rollbars.
forensicsteve is offline
Old 06-25-2011, 07:29 PM
Moderator
JimC's Avatar
The reason mine is removable is so that my grandkids can ride in the back seat still. You don't want to have those back seat passengers exposed to those hard metal bars in an accident. You need the back bars for the cage to be legal (the first level is a 5 point - two to the back, two coming down on the main hoop, and one going to the floor next to the driver footwell - but you might as well add the 6th point and have a bar going to the other side as well).
JimC is offline
Old 06-27-2011, 11:45 PM
2011V6Conv
2011V6Conv's Avatar
Not sure I understand - what part is removable? it seems that special bar you have is fixed and it makes the rear seat almost unusable, isn't it?
2011V6Conv is offline
Old 06-28-2011, 05:44 AM
Moderator
JimC's Avatar
The entire cage is removable. The door bars come out by pulling the pin at the top and the bolt at the bottom (I remove them for daily driving). Then the main hoop comes out by pulling out the 8 bolts in the floor, pull the back seat bottom out and undo the 8 bolts holding the back bars, and the entire thing comes out of the car.
A removable harness bar (the "special fixed bar") isn't track legal. Plus I wouldn't want my granddaugthers riding back there even with the harness bar removed. One side hit or quick turn and their heads would be hitting against the back bars. So yes, even if the harness bar was removable the back seat would still be unusable in reality.
JimC is offline
Old 06-30-2011, 03:30 PM
2011V6Conv
2011V6Conv's Avatar
I guess my question is whether the whole thing is removable easily (e.g. you do it once in a while, and sometimes have the car without the cage) or is it something that takes many hours and/or require a shop - and may be done only when you sell the car.
I've been thinking about getting a cage to be able to go on a track once in a while; but it is not something I want to be fixed on the car from now on ...
Quick Reply: Had to add a 6 point roll cage to the convertible
