Sponsored by:
Sponsored by:
Had to add a 6 point roll cage to the convertible
Old 06-30-2011, 06:08 PM
  #21
Moderator
JimC's Avatar
It takes about 15 minutes to remove the entire assembly and it is like it was never there - so the back seat can be used. The only thing left is the mounting plate at where the main hoop bolts in, but that is flat; and the plate in the front at the driver and passenger feet where the door bar mounts for the 5th and 6th points.
But the door bars are removable independently which is how I drive it daily. The door bars are out (except for the front plates which aren't in the way at all) and the main hoop and back bars.
This shows the plate in back where the rear passenger feet would be (before the interior was put back in)
And this is where the back bars bolt in
and with the rear seat in place
This is the 4 point section of the roll cage
Driver side door bar is removed here
JimC is offline
Old 07-01-2011, 01:05 AM
  #22
2011V6Conv
2011V6Conv's Avatar
Thanks JimC, this is very useful. Are all bolt-in cages expected to be so easy to remove and mount back in? 15 min sounds like a no brainer ...
2011V6Conv is offline
Old 07-01-2011, 03:26 AM
  #23
TPony
TPony's Avatar
A+ on the added stripe
TPony is offline
Old 07-01-2011, 05:55 AM
  #24
Moderator
JimC's Avatar
Not necessarily. The fabricator who made this one did another car and while it is a bolt in it is much more difficult to remove. The interior has to be taken apart because the hoop goes through the plastic and the mounting point is underneath. The MMR is like that as well; a good design and good bar but not easily removed once installed. We designed this one with ease of removal in mind, as well as where we could tie in to the frame rails without going through the plastic interior.
JimC is offline
Old 07-01-2011, 06:31 AM
  #25
Vader GT
Vader GT's Avatar
Sweet man, very nice workmanship!!!
Vader GT is offline
Old 07-01-2011, 07:03 AM
  #26
MeanStang08
ChopShop Mod-tator
MeanStang08's Avatar
Great detail pics too..
MeanStang08 is offline
Old 11-05-2011, 08:06 AM
  #27
Grethel88
Grethel88's Avatar
Default Roll bar
Hey Jim looks great. Do you have a contact name and number I would like to get one for my 2010 gt500 convertible thanks Jeff
Grethel88 is offline
Old 11-05-2011, 08:16 AM
  #28
Moderator
JimC's Avatar
I'll get his contact information for you. I have it, but can't find it on my desk, but I have a card in my car center console.
JimC is offline
Old 11-05-2011, 08:23 AM
  #29
Ditty
Ditty's Avatar
Originally Posted by Newwt
are hard tops still set at 12sec or did they change that? Do that make a roll cage that does interrupt the back seats? Gonna have to get a Baby on board sticker one day.
Capitol Raceway here in MD told me that if I ran faster than 12.5 I would NEED a helmet, and faster than 12.0, I'd need a FULL Cage as well. If not, I would be on the "Can Not Run List" (I'm guessing they take your info, pics of car and tag # and refer to that at tech.)
Ditty is offline
Old 11-05-2011, 07:10 PM
  #30
Moderator
JimC's Avatar
Grethel you have a PM, I don't know if Bobby wants it posted on the open or not.
edit
email it looks like, you must not have PM"s enabled but it let me send you an email.
JimC is offline
Quick Reply: Had to add a 6 point roll cage to the convertible
