Sponsored by:
Sponsored by:
Question about Mid Mufflers?
Old 07-05-2011, 04:11 PM
908ssp
908ssp's Avatar
Originally Posted by Norm Peterson
If you're going to add any supports, put a lot of thought into it. The closer to the engine you put them, the greater the effects from the engine torque reaction/rotation and thermal expansion will be and the more difficulty you'll run into between there and the engine. Stainless steel expands about half again as fast as plain carbon steel, so I'd plan on having to allow plenty of rearward pipe movement at any new hanger(s).
I'm guessing that it's only the driver side pipe that hits under heavy throttle, so you might be able to get away with adding just one hanger on that side for this situation.
If you're getting contact when driving over rough roads (from the mid mufflers weighing more than the pipe that they replace, plus the extra flexibility at what I assume are clamp connections at the ends), you might need a softish support on the passenger side as well. Not too stiff or else the passenger side pipe will pivot about the new hanger on WOT and will then move up toward the tank.
An "over-restrained" piping system is likely to be just as problematic for automobile exhaust as it would be for power plant steam piping, the main difference being that the exhaust system failure mode wouldn't be explosive in nature.
Norm
Thanks I'll keep that in mind. In 2010 they did away with the mounts from the X pipe to the transmission cross member. I might start by retro fitting that back on. As well as putting a stiffer rubber mount at the transmission.
908ssp is offline
Old 07-05-2011, 05:12 PM
Bmr4life
Bmr4life's Avatar
Norm is correct. I went through a lot getting those m80's to the point where my exhaust did not sag or rattle and my muffler tips weren't crooked. I did not have my m80's welded in, just used cheap u clamps. They held up good.
My car did have the under trans hangers which I feel are mandatory.
Bmr4life is offline
Roxon68
03-17-2016 08:13 PM
Vrooom
02-21-2016 05:25 PM
ctgreddy
10-14-2015 09:05 PM
09-10-2015 08:39 PM
Webster454
09-07-2015 04:59 AM
Quick Reply: Question about Mid Mufflers?
