Help w/ electrical gremlins- right side driving lights won't turn off.
Pull the access door off the kick panel and see if you can run a fan so you can get some airflow to dry the SJB out. Remaining moisture MAY be the reason you're getting some electrical tracking which can cause "unusual" electrical issues. 157dB can probably offer some advice if there's anything that can be done (spray the SJB with contact cleaner?) without the possibility of frying anything or compounding matters.
Any cellular store worth its weight has this stuff...
Inspect for any signs of corrosion.
Once the gremlins arrive, they dont
just leave once the leak is fixed...
SJBs continue to corrode as long as
there is 12Volts applied to them...
KEM Motorworks
08-14-2015 10:13 PM
