Auto Headlamps for $22 from Parts Guy Ed! - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 05-09-2012, 11:15 AM   #11
Diabolical!
Diabolical!'s Avatar
That's a shame. I never heard anything but positive reviews.
Diabolical! is offline   Reply With Quote
Old 05-09-2012, 11:29 AM   #12
jsimmonstx
jsimmonstx's Avatar
Quote:
Originally Posted by SOLER View Post
I need one for my 2008 also. Then I can disconnect the headlamp/key in ignition chime for good!
SOLER
9th item on this page - $65 (dealer wants $100 for the part)
Titus Will Ford Parts
jsimmonstx is offline   Reply With Quote
Old 05-09-2012, 02:03 PM   #13
SOLER
Default Just took me to the main parts page
Do you have a part number? I clicked on that link and it took me to the front parts page.
SOLER
SOLER is offline   Reply With Quote
Old 05-09-2012, 03:31 PM   #14
jsimmonstx
jsimmonstx's Avatar
SOLER
Sorry about that (poor web site design gets you every time - )
You have to browse to the correct car, and then in the list of parts categories, go to:
Electrical/Chassis Electrical/Switches
You'll get a list of parts in that category, and the headlight switch is the 9th item in the list.
Old 05-09-2012, 04:52 PM   #15
SOLER
Default Rog...
Thanks. I saw that part...Have two questions...
It only says it's for "with fog lamps" and doesn't specifically say it has autolamps. Does it actually do the autolamp funtion?
Also, for a 2008, do I also have to purchase and install the sensor, or is it included like the 2010-2013s?
Thanks!
SOLER
Old 05-09-2012, 06:39 PM   #16
wayne613
wayne613's Avatar
DRL's can be turned on from a dealership by programming the SJB for our cars (2005-9).
As far as true "automatic" lights goes(parking, headlamps, tail-lamps), no, you'd have to wire up something yourself, older models don't have this as an option, nor is there a sensor in place. The extra position the ordered switch for our 2005-9's will give you is for DRLs, and isn't actually necessary.
Other DRL options:
http://forums.themustangsource.com/f...nstall-448386/
Webelectric
Should you have to have "automatic", there are options to choose from, but nothing factory or factory accessory wise:
http://www.sonicelectronix.com/item_...cted-545T.html
Essentially requiring a board with basic logic to read a light sensor you would mount, feeding relays.
wayne613 is offline   Reply With Quote
Old 03-08-2013, 01:12 PM   #17
dvhstang
Default Motorcraft SW-6659 Switch
Quote:
Originally Posted by scottybaccus View Post
Wyatt is one of the crew that was helping me out. I figured they were well known, but I like to call folks out for doing good, not just all the bad we hear about.
For those needing it, the part number for the switch is 9r3z-11654-ca (Motorcraft SW-6659).
To install, you just pull two screws from the lower dash cover and drop it down (3 snap in clips at the top edge), remove one screw from the lower tab of the headlight/info button panel (one sanp in clip at the top), pull the plug on the back of the headlight switch, compress 3 tension clips around the back of the switch and pull it out the front of the panel. Reverse to install. Everything worked right away, no tricks.
I went out tonight and was all giddy at my lights working all by themselves. I'm such a geek.
I just ordered the Motorcraft SW-6659 switch from Amazon for $23.
dvhstang is offline   Reply With Quote
god help me. I need a bellhousing for a tr3650 Jskeezy84 4.6L General Discussion 5 09-08-2015 01:40 AM
Could I get a decent trade? kdryan 2005-2014 Mustangs 7 08-21-2015 04:01 PM
New from Pittsburgh chain New Member Area 6 08-17-2015 08:52 AM
Transferring suspension kits to newer Mustangs robjh22 S197 Handling Section 9 08-17-2015 07:35 AM
Want 400 RWNP for about 1500 bucks.... Soldier GT 4.6L (1996-2004 Modular) Mustang 9 08-12-2015 03:46 PM
0509, 2005, automatic, fog, ford, gt, guy, headlight, horizon, kit, light, mustang, parts, sale, starkey, switch, vehicle
