Sponsored by:
Sponsored by:
sporadic power drop
Old 08-01-2011, 02:17 PM
thewarmachine
thewarmachine's Avatar
Default sporadic power drop
My 2007 GT has recently been experiencing some kind of intermittent power drag like it does when the ac compressor kicks in. It is not the compressor, as far as I can tell.
Possibilities: Bad injector? fuel filter needs replacing? throttle body/MAF sensor cleaning? bad throttle control sensor in gas pedal?
Anyone else had this kind of issue?
thewarmachine is offline
Old 08-01-2011, 02:34 PM
Derf00
Gentleman's Relish
Derf00's Avatar
You say it's not the compressor (A/C) Does it only occur when the A/C is 'On'? If it does it's the compressor.
If it doesn't make any difference if the A/C is on or off, then I'd look at other things.
Derf00 is offline
Old 08-01-2011, 02:38 PM
thewarmachine
I am almost positive that it is not the compressor. I'll double check. Maybe it has incurred damage from working so hard in the heat wave.
Old 08-01-2011, 03:12 PM
Nuke
Nuke's Avatar
Can you be more specific on the symptoms? Is it in all power ranges? Amount of throttle? In a specific gear? Perspiring minds want to know...
Nuke is offline
Old 08-01-2011, 03:13 PM
allinon72
allinon72's Avatar
My guess is having the AC on + heatsoak.
allinon72 is offline
Old 08-01-2011, 04:05 PM
TWOKOOL
TWOKOOL's Avatar
Mine does the exact same thing. I am pretty sure it is only when the A/C on. I had the problem a little while ago about RPM's bouncing around when A/C on. I cleaned the TB and fixed that, but I still have the other issue.
Any help is appreciated.
TWOKOOL is offline
Old 08-01-2011, 05:01 PM
SaddleUp
SaddleUp's Avatar
It's God's way of telling you to upgrade to a 5.0.
SaddleUp is offline
Old 08-01-2011, 05:58 PM
pascal
S197 Section Modder-ator
pascal's Avatar
And how did God manifest himself in telling you to upgrade as well?
pascal is offline
Old 08-01-2011, 06:34 PM
JDWalton
JDWalton's Avatar
how many miles on the car? I would probably do plugs, fuel filter, spray out the maf with maf cleaner (or any residue free quick drying contact cleaner,) reset your computer, and redo your pedal calibration.
this all assuming you have enough miles to warrant that but for about $100 and 2 hours of work you cover a good amount of all the basic problems that manifest in this way, and are just good things to have done anyway.
JDWalton is offline
Old 08-01-2011, 08:52 PM
SaddleUp
SaddleUp's Avatar
Well, I had a run in my nylons that was in the uncanny shape of a running pony..... :O
SaddleUp is offline
Quick Reply: sporadic power drop
