beefcake tires, will they fit?
I am looking to change the wheels, damn tires for the 20s are more than I feel like paying for again. Anyways I was looking and found these, they are for the New Edge, 99-04, though. Will the 22mm and 24mm offset work on the S197s and will 275 up front and 315 in the back have any rubbing issues? Here is the link to what I am looking at
http://www.americanmuscle.com/black-...itto-stag.html
With that offset (which is about 22mm more than OE hence farther out) and a 315, even if you're NOT lowered any bump that will bottom out the suspension will most likely cause tire contact with the tire well edges. Also, 275's up front (like I have) will increase tramlining dramatically. I'd put a smaller width wheel up front and go with 255's there.
You obviously don't understand how you're affecting the OE tire footprint and OD. Try this: http://www.discounttire.com/dtcs/infoTireMath.dos
09-08-2015 11:50 AM
