Shaftmaster DS and BMR Loop Install
I have a Shaftmaster DS, and everything is fine until I get up to 95mph, then it vibrates.
Don Walsh from WalshHighPerformance whom I trust, and did not go to for the DS, says that the problem is the adapter, and the connecting parts for the shaftmasters not being the Ford parts. He has seen this time and time again.
I wish i would have known this before I was referred to this item. These complaints are common apparently. More money burned now to do it again with a 1 pc DS that saves the same weight and doesn't have a fitment and vibration reputation. Erik
Response from ShaftMasters regarding "vibration"
"We have improved internal vibration/harmonic dampening material in all of our current Mustang shafts. We have noticed shafts even run "quieter" in our balancer. Also, as is the case with all aluminum Mustang shaft manufacturers, most NVH can be attributed to improper pinion angle setting, installation of "rigid" rear suspension modifications, improper shaft installation or all three.
Our aluminum Mustang shafts are the only True Direct Bolt In shafts on the market and also the only ones with a 30 Day No Questions Asked Money Back Guarantee."
After market shocks, springs, UCA, LCA, LCA relocation brackets, and adj. PHB...
I have been running a Shaftmasters for several years now, and over 100,000 miles. No vibration on mine. And at the track I have had the car up to 110 with no issues. On the highway I can accelerate on the on ramp up to 80 with ease, and all is smooth.
