Weird startup after light installation?
Ok my dad is an electrician and we put a tester on the input and outputon the ballast and lights and the meter didn't show anything... But I'll try the test light and take it to discount auto too I probably need a new altimator or battery knowing my luck
Do you still have the OE MotorCrap battery? FWIW, I'd be more than surprised if you did with that Florida heat. Typically, many of the OE batteries aren't worth a darn.
I went and got my battery checked it was 450 cc amps instead of 590 so I'm guessing I lost a cell so there went a 100bucks down the drain for new one of those now I have to wait to get 4.10s
While you had the battery disconnected, did you use a test light to check for a drain? I, persoanlly would feel better knowing there is nothing going to hurt the new battery. You can also use an ammeter and check. Your dad should have that. The test light is much quicker and easier.
Yup we did the testing and there as no draw the battery lost a cell the cc amp were at 450 instead 590.. So I got a new with a whopping 650 cc amps haha it's all good now.. Going to the track tonight
