I am STUPIDDDDD
If you recognize and admit that you're stupid, then chances are that you'll be OK.
Real stupid people think that none is wrong with them since they possess very little to judge with...
So....... how would one know how stupid one is, if there isn't enough brain matter to make one aware of such a fact??
JD, you're welcome to resume posting on a regular basis.
Actually When I re-flashed from the FRPP stock tune that was really the BAMA 91 R tune so the SCT was good to go and I Re-flashed back to stock from the SCT. All is well.
Just thought I might be good for some laughs...
Considering I can join AARP in less than 2 years I should know better.
Restoring to stock tune, isn't that the axiom of switching handheld tuners? Even between two exact same hand held units?
I too am an amateur but I guess I could be wrong in assuming everyone is aware of this fact
Glad you were able to correct the issue, and thanks for posting this. Not only is it somewhat humorous, it's a good reminder to be careful with these tuners.
This is similar to the process of getting new tunes on the same tuner. You have to return the car to stock before you update your tuner and load the new tunes.
You were dumb, not stupid. Being dumb is simply not knowing any better, and it's not a bad thing, unless you don't correct it... then it becomes stupid. Stupid is bad.
You realized you were being dumb, and you fixed it. This means you're not stupid. So congratulations!
And hey, at least your SCT tuner worked. I haven't had that much luck with mine.
