Sponsored by:
Sponsored by:
Leaning on one side
Old 09-07-2011, 01:52 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Originally Posted by 2007CalSpec
I have an adjustable panhard and it's centered.
Dernit! that's where I was headed with my question about a pic....
If it's not that then the only thing I can think of is the spring seat is not properly set on the spring. Try switching springs between sides to see if it follows the spring or remains on the same side. If it follows the spring then you know it's a part defect. If not then it's an install issue.
Derf00 is offline
Old 09-07-2011, 03:13 PM
2cokeman
2cokeman's Avatar
This is a common complaint, I think I even may have seen a TSB in the past?
2cokeman is offline
Old 09-07-2011, 06:46 PM
09cs
09cs's Avatar
Anyone know what would cause the rear to lean on one side? I've noticed the passenger side is a bit lower than the driver's. It's not the springs because I swapped out my current rear springs, which are made by B&G, for my previous ones which are Steeda's. Still sagging on one side. Can't figure it out.
Is it because of the Shaker 1000 in the trunk?
09cs is offline
Old 09-07-2011, 08:12 PM
2007CalSpec
2007CalSpec's Avatar
It's not the springs because this happens with two sets of springs that I've tried and the spring seats look normal on both sides.
I have the Shaker 500.
2007CalSpec is offline
Old 09-07-2011, 08:15 PM
2007CalSpec
Today it didn't seem as bad when I was parked on level ground in a parking lot. It's barely noticeable to the naked eye but a tape measure can tell.
Old 09-10-2011, 07:39 PM
Stang-a-rang
Stang-a-rang's Avatar
I am having the same problem with the rear leaning more to the passenger side. I just lowered it, I put the Eibach Sportline Springs. I've even switched the springs from left to right, and right to left, with no change. I noticed that a Panhard bar was mentioned, I just have stock ones, could this help with adjusting how the rear sat?
Stang-a-rang is offline
Old 09-10-2011, 09:47 PM
oldlugs
oldlugs's Avatar
Anyone know what would cause the rear to lean on one side? I've noticed the passenger side is a bit lower than the driver's...
You're not mentioning the fat chicks you took out last week... Springs are gone.
oldlugs is offline
chrisdbassplayer
10-13-2015 06:53 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
ChampInSD
10-02-2015 04:55 AM
Drastang
09-29-2015 03:31 PM
Quick Reply: Leaning on one side
