Exhaust leak?! Video inside-need ideas!
A day or two ago I started hearing a 'ticking'(i guess) sound when I'm accelerating from a stop. Somewhere around 900-1k rpm it starts, and then is gone around 1200 or so. Does not do this at idle, and it won't do it in park, only when it's in gear. I've thought for a bit that I might have a leak, but that's only because I have some hissing from around the mid-pipe clamp, goes away when I give it a little gas. I'm not 100% sure what one sounds like. Anyway, car just hit 30k today. The car is properly maintained. The only mod is boomtube axle backs. Nothing else.
All I have is my digital camera, so there is some background noise. I had to put my headphones in to hear it really good. You can hear it best at about the 15 sec mark/48 sec mark. Once in the 20's I am trying to hold it on and around 1000 rpm so you can hear the ticking for a while. At about the 1 min mark you can hear the hissing I was talking about. Oh and just ignore my dogs in the backround(that is not my car doing that lol) Make sure you turn it up
Any help would be greatly appreciated guys!
I had an exhaust leak on my headers which I just removed yesterday, and was getting the same exact sounds. Just check and make sure allllllll the bolts on the exhaust are tight. and I mean ALL the bolts, including the actual manifold bolts themselves. If it still continues it might be the manifold gasket, but most likely its just something that loosened up.
Was yours doing it only at certain rpm's also?
Sometimes when you tinker around with axlebacks it can knock the midpipe enough to cause an eventual exhaust leak. I haven't done anything with my exhaust for nearly a year now but recently near curbs i can hear what sounds like a minor exhaust leak. The midpipe seems like it easily loses an ideal seal.
No problem man, and I would definitely bring it in. I didnt realize yours was a 2010 so yes they should fit it under warranty. Just have them put it on a lift and check all exhaust sealing points. Yes mine was present up until about 1500rpm or so and mostly in the lower rpms. Also I would hear a hissing when driving next to parked cars and walls. Even when you think everything is tight on an exhaust system, it can be tighter. I remember having a very small leak coming from a clamp on my midpipe after my header install. I tightened it up literally 1/4 of a turn and it stopped leaking.
Well no the leak I had from the clamp was a while back, sometime in like January. The leak I just recently had before I removed my headers was actually a bad header gasket, but I was getting the same sound. The ticking sound was coming from closer to the motor and could be heard if you put your ear right next to the driver side wheel. I havent started the car yet with the stock manifolds and h pipe back on yet, but I am confident that was what was causing the sound. Like I said just tighten up ALL the bolts on the exhaust system and see if that fixes it. With the way exhaust systems heat up and cool down, things become loose and this is what causes leaks. Its nothing major, everything just needs a tightening every once in a while.
Well, work has been insane this week and I can't get away for ****, much less sitting up at the dealer all day. I'm thinking if I can get a bit to run out tomorrow I might just try and run by an actual exhaust shop and see what they say. Good, bad?
