REAR END NOISE! - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 09-29-2011, 05:04 PM   #11
FordService
Official Ford Rep
FordService's Avatar
Quote:
Originally Posted by 2010stanger View Post
OK guys i've been hearing a humming noise that seems to be coming from rear end when i reach speed from 60mph and up and pressure on gas pedal. As soon as i let go of gas noise is gone! dealer has said that the rear diff is fine and noise is coming from exhaust resonance. is this possible?
Hi 2010stanger,
Are you still hearing the humming noise? If so, Please PM me with your VIN, contact information, mileage, & servicing dealer name/state and I will assist. Thanks!
~Natasha
FordService is offline   Reply With Quote
Old 09-30-2011, 04:08 PM   #12
2010stanger
i dont think theres much you can do to help... dealers have looked at the car and have told me that its a mix of muffler and drive train resonance. Told me there is no abnormal noise coming from rear diff. They refuse to open up diff for no reason
2010stanger is offline   Reply With Quote
Old 03-10-2014, 07:19 PM   #13
BULISTC
i have had two 08 bullitts. i have had this problem in both. i can hear the whine from around 30-80mph. after eighty i cant hear anything. i always thought it might be the exhaust. but,, now im not sure. after seeing this:
Year: 2010
Model: Mustang
Model: 09-20-4
TSB 09-20-4  AXLE WHINE Publication Date: September 28, 2009
FORD:
2005-2010 Mustang
This article supersedes TSBs 8-21-6 to update the vehicle model years.
ISSUE:
Some 2005-2010 Mustang vehicles may exhibit excessive axle whine noise.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
This condition may be corrected by installing tuned dampers on the rear axle assembly, if not already installed.
1. Check the rear axle assembly for the presence of tuned dampers. (Figures 1-2) Figure 1 - Article 09-20-4
Figure 2 - Article 09-20-4
2. If not present, then install tuned dampers. Refer to the installation instruction sheet included in the damper kit.
NOTE:
NO DRILLING IS REQUIRED IF DAMPER MOUNTING HOLES ARE PRESENT. VEHICLES BUILT AFTER 11/15/2004 ALREADY HAVE THE REQUIRED DAMPER MOUNTING HOLES.
3. If whine noise persists, then continue with normal diagnostics per Workshop Manual, Section 205-00.
PART NUMBER
PART NAME
5R3Z-3C246-A
Damper Kit
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION
DESCRIPTION
TIME
092004A
2005-2010 Mustang: Install Axle Damper Kit Includes Time To Drill Holes If Necessary (Do Not Use With Any Other Labor Operations)
0.6 Hr.
DEALER CODING
BASIC PART NO.
CONDITION CODE
4010
d9
i still have thw noise. it sucks. do you??
BULISTC is offline   Reply With Quote
Switching from 3.89 to 3.00 gears... musnicki Classic Mustang General Discussion 8 09-23-2015 07:11 AM
Upgrading to handle slicks? Info needed Dragonus18 4.6L (1996-2004 Modular) Mustang 8 09-09-2015 01:21 AM
03 V6 Mustang Ticking Noise Emblazoned General Tech 0 09-03-2015 10:45 PM
Best Place To Run Power Wire/Firewall '08 cbird1177711 2005-2014 Mustangs 3 09-02-2015 08:51 PM
01, 2008, 55mph, chatter, cobra, differential, end, ford, gas, letting, mustang, noise, rear, rearend, whine
