Question regarding running different size tires front and rear
How is that staggered???lol
You have alittle more diameter, which is probably a good thing and moving about 1.6" in from where your back edge currently sits. Provided it was a 2010+ CS setup, it shouldn't rub.
I torque mine to 80-85lbs. I usually don't worry about the lugs until I have seen the wheels. Seating patterns are not universal so a trip to the local NAPA goes with the process for me, but as it a CS package i'm sure a quick search (get off your lazy azz) on the MF will give you the answer
From the initial post, you can see that I was interested in picking up a staggered wheel+tires. But I dropped that idea because of not able to swap front/back tires down the road.
Hence, the CS wheels.
fine, ill do a search! -_-
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
inyadreems
08-21-2015 09:10 AM
MtnMustang
08-16-2015 08:07 PM
