Q about Fuel filters...
#31
I'm going to do the above process over my month off from college and put in a mobil one or wix filter for sure.
#32
I'm the same way, I was in a rush to get my oil changed this past time, ended up having to buy a Fram filter, then did some research and found out what POS filters they make despite being so popular, and I almost went out to drain all my oil that day to collect it, replace the filter, and then put all of that oil back in lol. I run 10,000mi intervals so I know I'll have to replace that filter earlier than that, but still I shouldn't have panicked *that* badly lol.
#34
I posted about the AC/Fuel line tools b/c it IS recommended to use them to minimize breaking the clips. If you break a clip or eff up the inside of the hose end that attaches to the filter, you're screwed. It's a "Do it right, not twice" thing. I'd rather take the extra time and have the right tools and NOT eff anything up, than go the quick easy way and end up breaking something and be stranded until I fix it.
#35
There is no tool required to remove the hoses from the fuel filter on a S197 Mustang. There are dual green tabs, one on both sides of the connector. You simply push in, and they will release.
Wix versus Motorcraft fuel filters, I've noticed that the drilled hole on the inlet and outlet of the Wix filter is slightly smaller than on the Motorcraft fuel filter.
This will not be an issue for a N/A V8 or V6, but could be an issue for a very high HP/TQ supercharged application. It may not make much difference at all, but was an observable difference.
#37
Concerning this lack of slack, how do i pull the lines to reconnect both ends to the new filter?
#38
Not totally sure if the setup is the same on the 2011s as on the 05-09s since I haven't gotten under my 2011 to swap mine yet. But on my girlfriend's 06, by removing the bolt that clips the filter itself in right up against the rail, you can sort of swing the filter away from the rail and it gives you some more wiggle room to attach the lines on both ends.
#39
I watched the little tutorial on american muscle's website. Bought the motorcraft filter from advanced auto. Jacked up the stang, and had her back on the road in a matter of minutes. Only 20,000 miles on an 08 GT. Fuel coming out of the filter looked super clear. Probably didn't even need to do this. Eh, only $10 for peace of mind.
mrappe
09-26-2015 10:16 AM
