WTF, ANOTHER GREAT IDEA
#81
The next oil change came due, but instead of changing the oil....I left the old oil in the engine and told her it was changed. She came home the following day and said her car drives so much better now, thanks for changing her oil.
I laughed, and showed her the new oil and filter in the shop that was never put in her car. She got made at me because I proved I was right.
I think that the time interval is also important. I have my oil changed about every 1500 miles, which is every six months. I want the acid, condensation, and any other nasty stuff drained. For me, it's not the oil or filter that could be problematic; it's the possible accumulation of crud.
Severe service schedule is 15,000 miles or one year, whichever occur first.
We currently have an 06 Volvo XC90 in the shop. the lady does at least 20K between oil changes.
she came in on wed. and said its making an odd noise and it says low oil pressure.
The engine is sledged up, the oil pump is cooked. and the motor has pretty much no lubrication. it needs a new motor..at 90,000 miles.
CHANGE YOUR OIL!
CHANGE YOUR OIL!
#82
I checked my owners manual, and I discovered that for 2011 plus GTs, using the Motorcraft blend (not the true synth), they recommend up to 10000 mile oil change interval.
For harsher conditions (towing, dusty unlaced roads) or hard spirited driving, the interval recommended drops to 7500 miles or less.
Using true synth oils, I don't change it until 10k miles because I do not drive hard nor do I go off road or tow.
#83
Edit - the unedited version of this reply was posted before I saw that Jim had provided the necessary information. Anyway, if you're going to post a number, be sure to describe the usage that it applies to. Otherwise it doesn't mean much.
Did you happen to notice which driving schedule that 10k applies to?
Is it for whatever Ford is including under their description of "severe"?
Or is that the "normal driving" interval?
I strongly suspect that it's the normal schedule, but feel free to correct me if you find out differently.
Norm
Norm
#85
The extra 1.5-2.0 quarts of oil in the new 5.0 sump helps to achieve a greater oil change interval for sure. Even cheap synblend Motorcraft can achieve 7,500-10,000 miles.
Imagine what a true synthetic could achieve with 8 quarts. Amsoil's Signature Series lubricants are able to achieve 15,000 miles (severe service) with a 6 quart sump. Maybe a little longer with 8 quarts, but I have no desire to exceed 15,000 miles per fill. IMO, the oil has paid for itself in that duration and is worthy of a change.
#86
The 10,000 is for normal conditions. But the neatest thing now is that the 'Info' section in the instrument cluster now allows you to check the status of your oil life. This is a projection based on the usage parameters that Ford has set for the engine [whatever they may be].
#87
As BillQ said, the Intelligent Oil Life Monitor calculates the oil change interval, up to 10k miles under normal conditions. It could be accelerated by situations including towing, short-distance driving, and extreme temperatures.
We offer a Maintenance Schedule at Owner.Ford.com that can be customized to your specific vehicle. You can also get quarterly service offers from your local dealer here. Check it out!
~Natasha
M3hunter
09-05-2015 03:42 PM
