Sponsored by:
Sponsored by:
Burn my clutch?
Old 12-22-2011, 01:28 AM
SkyWitit23
SkyWitit23's Avatar
Default Burn my clutch?
Hey guys im wounding if I burned my clutch alittle bit? I was on a incline around my area, cause a civc so happend to be in a tree and stop ongoing cars..now mind you I'm on a incline on a turn..So I go forward to turn around,then reverse then back into first, and then all the sudden I started to smell a burning wire smell? like, as if wires was burning?? It lasted for a minute or so ?? I smelled this smell a total of 3 times before, the car has 6k now so I'm wondering am I burning my clutch if I smell this type of smell? Are these new trannys durable? So If I did burn it alittle bit willl it do damage? do I have to worry and panic if I do it again? Thanks guys
SkyWitit23 is offline
Old 12-22-2011, 01:03 PM
SkyWitit23
SkyWitit23's Avatar
Anyone?
Old 12-22-2011, 01:45 PM
hammeron
hammeron's Avatar
probably a little bit, but don't sweat it.....if there are no issues now
then keep on keeping on.
hammeron is offline
Old 12-22-2011, 02:08 PM
simplexdesign
simplexdesign's Avatar
+1^. There are inexperienced drivers that burn up their clutch a lot more than 3 times and it holds up. Just don't make a habit out of doing it because if you are smelling it you aren't using the clutch properly and will need a new clutch sooner.
simplexdesign is offline
Old 12-22-2011, 03:42 PM
Jas5
Jas5's Avatar
dont worry too much about it... i mean you probably were burning it up, you want it either fully engaged (in gear) or not at all (neutral)... the in between is when you start burning her up. Dont try to do burnouts or drag racing clutch dumps and it should last longer
Jas5 is offline
Old 12-22-2011, 04:55 PM
SkyWitit23
SkyWitit23's Avatar
Yeah I was kinda wondering if that smell was the clutch, I do fully engage or natural but sometimes i do get caught in high Rpms with the clutch just about to be ingauged, but that's if I'm on a hill or quick situation, but this is my first manual car ANSI pretty much got it down, it's just certain situations..but how strong are these clutches? Also if i never smell the clutch that means im doing it fine correct ? Thank u guys for the feedback.
CS2007
06-25-2019 09:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
jrrhd73must
10-02-2015 09:17 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Burn my clutch?
